| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I read this over in another forum:
Data comes off the CD transport itself as I2S data, which seperates the bit clock and word clock out from the PCM audio data. This format is, for all intents and purposes, immune to jitter. It then hits a digital converter, which then spits out S/PDIF. On the other end, a DAC that has a S/PDIF input driver, or a S/PDIF to I2S converter, then the DAC. Now why exactly more high end transport/DAC manufactuers aren't using external I2S is beyond me. Audio Alchemy used it a lot, so did Sonic Frontiers. I think Camelot still does, but I'm not sure as their web site is garbage. You'd think on a $2000 CD transport they could put $1 worth of parts in for an I2S jack. Now I'm really confused. What's with all the jitter readings for USB-to-I2S convertors then? What would be a good transport for getting I2S data out then?
jitter critter. |
#2 | |
#3 | |
jitter critter. |
#4 | |
The I2S interface conceptually is well laid out for low jitter data transport. However everything depends on implementation hence low jitter master clocks should be sitting at the DA, and reclock all incoming (jittery) data With USB, the clock at the DAC cannot always be the slave, so there you go...... Philips CDpro2 is a good drive with I2S out best |
#5 |
Guido,
Thank you for that reply. I still have much to learn - which, surprisingly, I am pretty excited about! ![]() Cheers!
jitter critter. |
| Confused about DVC and Q | mashaffer | Multi-Way | 13 | 30th July 2006 03:40 PM |
| Confused - Can You Help? | Steveal | Full Range | 16 | 1st July 2006 08:59 AM |
| i'm confused ... | sss | Multi-Way | 5 | 11th May 2006 12:03 AM |
| Page generated in 0.07899 seconds (79.51% PHP - 20.49% MySQL) with 10 queries |
