Mini-DAC with balanced output - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th December 2002, 02:53 AM   #1
andrei is offline andrei  Canada
Default Mini-DAC with balanced output
Hi everybody,
I just finished building my first digital audio project, and I thought
I'd submit it for a public review. It is a small and relatively simple
DAC built around latest Burr-Brown/TI chips, with a few design choices
that are uncommon, but seemed interesting to me.
Here are the specs:
  • 96kHz/24bit Toslink input
  • balanced output (2.47Vpp full scale)
Chipset:
  • DIR1703 DAI receiver
  • PCM1730 advanced segment DAC (Delta-Sigma)
  • passive RC-L-RC I/V converter and 3rd order Bessel filter
  • THS4131 fully diferential amplifier in output stage
  • TL431 shunt regulators in digital supplies
Digital part is pretty much datasheet implementation, except for fairly
elaborate power supplies. Analog circuit is more interesting, with
passive I/V conversion and low-pass filter followed by fully
differential gain stage. The whole thing fits on a 8x10cm PCB, and can
run from 6V battery power. I assembled and tested a prototype, and it
works. Datastreams up to 96kHz/24bit are supported, and the noise floor
is low (below that of my amplifier). Subjective sound quality
evaluation will take some time, though...
So, what do you guys think?
P.S. I have a few spare PCBs if anyone is interesting in building this...
Old 8th December 2002, 07:36 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
Good work.
Do you have picures of a built DAC?
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 8th December 2002, 09:28 PM   #3
I would get rid of the filtering on the output. You only need a single pole of filter around the balanced amp. The other parts will simply mess up transparency.
Use the best Blackgates everywhere: Ns or NXs.
Ric Schultz
Old 10th December 2002, 09:22 PM   #4
To peranders:
Thanks... I don't have a digital camera, so no pictures for now. Maybe some day...
To Ric Schultz:
I thought about it, but felt that passive filter will create less problems than it absence would cause. PCM1730 is a delta-sigma DAC, after all, and there is a fair bit of out-of-band noise on the current output (although BB says much less than single bit modulators). Feeding this into feedback loop is asking for trouble, even with such a fast chip as THS4131... Eliminating the passive filter and doing active I/V conversion with THS4131 will bring the cost and board space down by a factor of almost two, so it is certainly an option...
BTW, I am using Panasonic SP-Cap specialty polymer electrolytics for bypass duty, since they have low impedance at high frequencies.
Old 9th May 2004, 02:37 AM   #5
Any update or photo on this project?
I am interested in a full balanced DAC project!
Thomas
Old 10th May 2004, 03:45 AM   #6
Sorry, still no photo... Although I have a digital camera now, so I can take one if you really want to see it .
I have build another DAC with balanced output since then, which I like better. It uses better digital filter and DAC chips (NPC SM5847/SM5865). Output stage is still THS4131, but power supply has been significantly improved. Photos and schematics are posted in this thread.
I am currently re-designing my NPC DAC to improve jitter rejection. I am going to reclock digital filter and DACs from local buffered low-jitter DCXO (CY23FS04) locked onto the recovered interface clock. Cypress promises 55db of jitter reduction at 1.7kHz, which is a lot .
Old 10th May 2004, 03:52 AM   #7
Coulomb is offline Coulomb  England
Coulomb's Avatar
Default Re: Mini-DAC with balanced output
Originally posted by andrei
Hi everybody,
Here are the specs:
Chipset:
How much for the PCB's Andrei, I would like to try it out.
Anthony
Old 10th May 2004, 04:09 AM   #8
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
I should buy a board too. I could stick it in my cd cd player i just bought..
Cool..
Old 10th May 2004, 04:26 AM   #9
I think I have two (or maybe three) boards for PCM1730 Mini-DAC left, $25 US (plus shipping) to cover manufacturing costs.
Old 10th May 2004, 12:27 PM   #10
borges is offline borges  Norway
andrei, do you see any ill effects of the finite output impedance of the DAC? Have you done tests with pure input tones and then looked at the output spectrum to test for harmonic errors?
I'm asking because I plan to do something quite similar to your design with the PCM1794.
By the way, how big a role do the power regulators play? On my board (which will hopefully get here in the mail soon) I have just put down a 337 or 317 for each power rail I use. I use separate regulators for analog and digital with a common wire feeding all positive regulators.
Greetings,
Břrge
Finding pre-amp output in mini system chuck55 Solid State 20 14th May 2009 10:16 PM
Balanced output transformers for 2 x 6L6 jean-paul Swap Meet 4 8th September 2006 10:03 AM
ono balanced output pamaz Pass Labs 6 3rd March 2004 11:20 PM
balanced output wuffwaff Solid State 14 16th January 2002 06:54 AM
Copyright ©1999-2017 diyAudio
