| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 | |
#12 | |
to answer your questions: On the Attraction DAC I use the TDA1543 because it is R2R and because it can be used with a single-ended power supply. As you already know, the Attraction DAC is designed to be powered by a Optima Red Top 12V car battery which eliminates the need of wall powered (noisy) supplies. I use active I/V conversion 1 OPA134 per channel, and 4 OPA134 per channel as output buffer. The DAC can power a speaker directly ![]() The output level is as high as it possibly gets with a 12V supply, so it is about -3.5 Volts to +3.5 Volts full scale (which btw. seemed to be enough to overdrive DUC's preamp). The input (spdif) receiver is custom. I programmed it into a Xilinx device. It has a switchable JISCO option and all DACs come with the UPCI (ultra-precision PLL) which synchronously reclocks the data. There is 2 custom made VCXOs for the frequency generation and tuning and one custom XO for the JISCO function. All features programmed into the Xilinx, which was really fun, but no walk in the park, btw ![]() The Attraction DAC runs up to 192kHz on spdif input. It uses neither upsampling nor oversampling. Just straight conversion. So above the more obvious stuff. But why is it so damn good ? Okay, the pcb is flat on the bottom, which means that all through-hole solderjoints have to be flat. There is no housing and the high-quality RCA jacks are not connected via wire, but directly soldered to the pcb. Then this pcb is screwed on a spruce board which is the reason the pcb-bottom has to be flat. Mounting to the spruce board adds body to the sound (which otherwise is not there). Then there are a couple of other tricks I apply with the DAC which I better not mention here, in order to prevent some avalanche-kind of response ![]() However, now you have something to play with ... Fun ![]() Charles ![]() ALTMANN MICRO MACHINES |
#13 |
Thanks, Charles, to your answer here - highly appreciateted!
Spruce: I also do that occasionally - mostly because I am too lazy to make a proper case - but why not! But we should not forget to use some layes of C37 DAC: Can you explain how the TDA1543 can take a SR of 192kHz? And: You do have to explain to us your "tricks", but please tell us a bit more, will you?
/lohk/ |
#14 |
corr: a TDA1543 can obviously take 192kHz sample rate, in 16bit resolution
( - should have read the specs before asking - )
/lohk/ |
#15 |
Charles, have you experimented powering the OPA134s with a separate battery? Would be easy to implement and probably would further improve performance.
#16 |
I understand most of the tech stuff going on here... but a spruce board for "adding body" to the sound?
jitter critter. |
#17 | ||
![]() Quote:
However, the OPAs get the pure battery current, then comes the DAC (regulated) and then comes the digital section (regulated separately). Ground plane separation plays an important role too among other things. I think if anyone of you would spend 5..10 years of his life tweaking with DAC issues - add a portion of luck - add an extra portion of ignorance - you would all come to quite similar results ... Charles
#18 | |
Charles, If I may ask how do you make a dual supply for the op-amp with a single 12vdc ? |
#19 | |
Hi Will, I feed the signal at 6V, just about in the middle. That's the reason that the Attraction DAC has coupling caps at its output. Charles
| Altmann's Split Feedback concept | tigro | Tubes / Valves | 1 | 18th January 2009 10:07 AM |
| Altman Attraction DAC. Ulas, Poobah, rfblw, Guido, anyone? | MGH | Digital Source | 10 | 26th August 2006 09:17 AM |
| The attraction of vacuum tubes / valves. | Circlotron | Tubes / Valves | 135 | 17th March 2003 01:37 AM |
| Has anyone fooled with the $5 Altmann tone arm? | hard times | Analogue Source | 0 | 10th October 2002 03:52 PM |
