Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
defective Revox B225 sings like a bird
Old 6th August 2006, 12:58 PM   #1
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
Question defective Revox B225 sings like a bird
i have a B225 that I ( try to ) repair for a friend, when I play a piano CD it only sings like a bird "tschilp" and also there is 50Hz hum.
The 50 Hz hum looks like a bad supply voltage, supply voltages seem to be ok, +/- 12 V for analog, for the TDA1540 -5V , +4V ( taken via R lytic-C from 5V line ) and -13V ( is that enough ??? )
Havent looke with a scope though.
Already changed all SAA ICs without succsess, the RAM I don't have.
Any hint where to search ?
While we are at it, I have another bird here, my Analyzer.
On power up there is no problem, then after a few minutes it goes partly off with a "tschirp" ( I think it comes from the switching PSU ), no screen and no LEDs on plug in.
One minute later it goes on again, the processor of the plug in needs a restart of the whole machine.
And then it usually works forever.
When it is warm in the room, there isn't any problem at all, but when it is cold, it is getting more serious, fails after minutes again and again.
Looks like it fails at a specific temperature which is very ugly...
Old 6th August 2006, 01:22 PM   #2
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
I have no idea about your Revox, but for your analyser, I'd start with a blanket resolder. That sort of symptom is quite likely down to a dry solder joint somewhere.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 7th August 2006, 11:27 PM   #3
phimor is offline phimor  Australia
phimor's Avatar
Bernhard,
the Revox, is the noise in the output or from the transport.
Sometimes, if the focus servo is to tight the transport will 'ring' like a bell.
Otherwise its most likely the power supply. I always change all the 'litics, cures 90% of problems.
Cheers
Philippe
"Everything else is gaslight"
Old 8th August 2006, 01:43 AM   #4
anatech is offline anatech  Canada
anatech's Avatar
Hi Bernhard,
Did you have a look at your supplies with your 'scope first? I too have found many bad electrollytics in these. The chips would be my last resort.
-Chris
Edit: The tracking servo oscillates in the 500~600 Hz range since this is a one beam system.
Old 8th August 2006, 08:58 AM   #5
Bernhard's Avatar
The singing is not mechanical sound from the transport / laser, it comes from the audio output instead of music.
First there is the singing that gives the impression that data format is corrupted ( but that usually sounds noisier ) and ten there is 50 Hz hum.
Old 8th August 2006, 11:41 AM   #6
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Hi Bernhard,
For B225, looks like the dac is kaput.Use the scope to see the output of left/right channels.I think your analyer's switching supply should be investgated also.
Old 8th August 2006, 11:41 AM   #7
Sorry,
One can't see a waveform when dac has current output so you have to go to output of analog stage, which is the opamp and if the output is distorted then you have to guess if it's the dac or opamp.
Old 8th August 2006, 11:44 AM   #8
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Originally posted by Bernhard
50 Hz hum.
Try replacing the 100F cap on the 33V rail in the PSU.
/Hugo
Old 8th August 2006, 11:56 AM   #9
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Default Re: defective Revox B225 sings like a bird
No , it must be -18 volts... inspect the electrolytic caps in this voltage rail...
Jorge
Old 8th August 2006, 12:06 PM   #10
Bernhard's Avatar
Default Re: Re: defective Revox B225 sings like a bird
Ah..., also the TDA data sheet says min -16,5V and max -18V,
but hey, it's aRevox
defective Revox B225 sings like a birdHide this!Advertise here!
ReVox B225 Zen Mod Digital Source 16 29th October 2010 10:51 AM
Revox CDP B225 Service Manual Needed bordins Digital Source 4 29th January 2006 10:21 PM
Revox B225 Zoran Digital Source 2 15th November 2005 06:29 AM
revox b225 waltube Digital Source 0 19th February 2005 02:41 PM
Revox B225 Clock speed lancer Digital Source 4 20th October 2004 10:52 PM
Copyright ©1999-2017 diyAudio
