Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th August 2006, 02:24 PM   #1
Default Src4392 + Ad1865???
I'm curious if anyone has any thoughts on using this combination. The SRC4392 is a new part from TI that includes a DIR/DIT and an SRC. Seems to me this could be an ideal device for interfacing with the AD1865. I still have lots of reading to do on the SRC datasheet, but any guidance would be appreciated. So far I have only built a simple NOS-TDA1543 DAC, as well as PCM2906/2706 USB DAC's so this is a big leap for me. The SRC will need to be controlled by a microchip, which is not a problem for me. I was thinking of using a PIC16F88 which I am familiar with, but the 18F4550 is awfully tempting.
Any guidance or suggestions would be appreciated.
If you take something apart and put it back together again enough times, eventually you will have two of them.
Old 5th August 2006, 06:59 PM   #2
cyl is offline cyl  Hong Kong
I want to use SRC4392 but my first problem is the 48TQFP. Can you find any cheap adaptor or prototype board?
Old 6th August 2006, 03:29 PM   #3
Don't be scared off by that SMD package. They are no more difficult to solder than anything else. It takes a few more minutes to get it aligned, but the soldering is easy. Just apply a wad of solder over all of the pins, then use a desoldering braid to pick up most of it. Check between the pins with a magnifying glass after you are done. I think you will be surpried with how easy it is.
Of course all of this is pointless if you are intending to use protoboard and need the part in a DIP format. I was actually intending on designing a board for this project.
G.
My DAC on AD1865 waldez Digital Line Level 1 21st April 2009 01:38 AM
My AD1865 nos dac purer Digital Source 10 6th July 2008 03:45 PM
SRC4392 or AD1896 Lorien Digital Source 11 14th February 2008 08:14 PM
Anyone tried new SRC4392? andrei Digital Source 3 3rd July 2006 03:10 AM
AD1865 w/ USB? dsavitsk Digital Source 6 28th February 2006 10:47 AM
Page generated in 0.05591 seconds (80.91% PHP - 19.09% MySQL) with 10 queries
