CD-ROM as a transport... - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th December 2002, 03:28 PM   #1
Default CD-ROM as a transport...
Hello!
I have a Plextor UltraPlex 40X SCSI CD-ROM, and I am going
to build a dac to make a coplete cd player(using BB DIR1703, DF1706 and probably PCM1704), so I have some questions...
...for starters, how should I connect Plextor to DIR receiver,
probably spdif on the back of Plextor, but matybe there's a room
for some twekas ie. transformer coupling or anything else??
Power supply for Plextor...well, undoubtedly there's a better
way than PC power suppley
What about vibration damping, does anyboady have suggestions
for this, how should the case for the entire 'player' look like?
Finally, the problem with play control, Plextor itself has an 'eject'
and a play/next button. Does anyone knows, how to make use
of forward/rewind etc. etc.
I suppose that it has something to do with SCSI bus and SCSI commands...
Thanks!
Adam
'Miracles are miracles, faith is faith and life is life'
Old 5th January 2003, 02:46 PM   #2
Send a message via MSN to Tazzy
Any luck in finding info? I've got a 12x plex I could use to experiment on ;-)
Old 5th January 2003, 03:59 PM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Check this:
How to convert cd-rom into audio cd?
cd rom as a transport?
You cand do search under CDROM and transport and probably find more info on the forum.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
DIY transport w/ CDROM drive vs player as transport dw1narso Digital Source 8 17th April 2016 07:14 PM
Cd-rom , Like A Best Transport ??? everflow Digital Source 1 6th February 2008 10:18 AM
My transport seems to be ill dsrviola Digital Source 0 28th December 2007 07:46 AM
PC as a transport SashaV Digital Source 17 16th April 2007 11:15 AM
Cd Transport costiss Digital Source 6 2nd January 2003 04:22 PM
Copyright ©1999-2017 diyAudio
