Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd August 2006, 12:08 AM   #1
pooge is offline pooge  United States
Default F-connector vs. BNC
Is there any good reason why a BNC should be preferred over a good quality F-connector for transferring digital audio? I'm talking about a GOOD F-connector, i.e., 3GHz barrel rated at greater than 25db return loss, compression vs. crimped male, etc. From the specs I've seen, these F-connectors have better shielding than a BNC. So why not use them instead of BNC?
Old 2nd August 2006, 12:11 AM   #2
mrshow4u's Avatar
...just make sure you get a 75 ohm BNC. Most are 50 ohm. If you were choosing between high quality, I don't think there'd be a difference. Canare makes really nice versions of both
".........These go to eleven"
Old 2nd August 2006, 02:20 AM   #3
jackinnj's Avatar
a BNC connector won't fall off.
Old 2nd August 2006, 11:32 AM   #4
I don't think Canare makes a compression F-connector. They a crimp connectors.
How does an F-connector fall off?
Old 2nd August 2006, 01:12 PM   #5
jackinnj's Avatar
I hate F connectors -- the bare copper can get oxidized over time. I think they are prinicpally used because the connection is quick and inexpensive to make -- no fiddling with a center conductor which has to be soldered. The consumer VCR/Cable Box F-Connector will always come loose, but I doubt it's a problem for the screw type.
Old 2nd August 2006, 01:36 PM   #6
mrshow4u's Avatar
The Canare "F"'s don't suffer the oxidized copper problem. They use a tightly crimped, gold plated pin.
....machined threads too. They're pretty sweet.
Old 2nd August 2006, 08:53 PM   #7
SisterOfMercy's Avatar
F-connectors are more suitable for a permanent installation. I haven't worked with the Canare F-connectors, but you don't want to disconnect a normal F-connector too often.
Name this Connector thermionic Parts 7 16th July 2009 03:31 PM
Can I use 4-pin Molex connector as speaker connector? MikeHunt79 Everything Else 5 3rd June 2009 07:21 PM
ID PCB connector for me please? markiemrboo Chip Amps 3 11th November 2006 12:19 PM
AC connector alizawi Chip Amps 10 4th April 2006 02:43 AM
ATX connector MaXiZ Everything Else 15 3rd January 2006 08:02 AM
Page generated in 0.09319 seconds (79.27% PHP - 20.73% MySQL) with 10 queries
