Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st August 2006, 12:51 PM   #1
Question help on LC7822N
Hi
I am currently buliding my own home thearter amp
so for the audio input selection section I found
a ic LC7822N in a old Oknyo Amp I had lying around..
now my question is how do you togle the various internal
switches on this Ic
I would like to simulate this on my breadboard before
I start writting a program for the PIC wich I wish to use
to control the whole amplifier.
I have read through the datasheet but i still don't understand how to do this.
Your help will be greatly apreciated...
Thanks in Advance.
Here is the Datasheet
Old 2nd August 2006, 07:48 AM   #2
What part don't you understand ?
Old 2nd August 2006, 08:38 AM   #3
Thanks for your reply...
ok here I go...
1. on the CE I put a Logic Low
2. I have to clock through A0 A1 A2 A3
3. take CE to a logic High
4. Then Clock through SW1 SW2 SW3 SW4 SW5 SW6 SW7 SW8
5. take CE to a logic Low
I am not sure What A0 A1 A2 A3 are suppose to be
I see that they are dependent on the s pin.
can I just tie the S pin to gnd & just use 0011
Thanks Again...
Old 2nd August 2006, 10:17 AM   #4
ok here I go...
Thanks Again...
The S pin gives you two different addresses for when you use two chips. With one chip you can, as you say, ground the S pin and use 0011 as the chip address.
Old 2nd August 2006, 10:44 AM   #5
Thanks again....
now I get it....
Thanks a million for your Help Greatly apreciated
now I can Go on & Build ....
Page generated in 0.07778 seconds (77.08% PHP - 22.92% MySQL) with 9 queries
