| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I took PCM2702 with wire in a circuit board. At first, I forgot to give 3.3V to 2 and 4 feet of PCM2702. When I connected it with USB port of computer, it appeared unknown device in my computer. At this level I remembered the status of PLAYBACK and SSPND, the LED to these two feet was normal.
When I gave 3.3V to 2 and 4 feet of PCM2702, I found the LED to PALYBACK did not brighten but the other SSPND could. I checked it many time and anywhere of the circuit, but I could not find the reason and I am very strange that the voltage in PLAYBACK foot is 3.3 always. I want to know any guys have good idea for this problem. Thanks. Another thing, I do not very sure if I connected the correct way for the CLOCK OSCILLATOR, I checked the voltage at XTI was 1.78V and XTO was 2.8V, are there correct?
flying without wings |
#2 |
I took PCM2702 with wire in a circuit board. At first, I forgot to give 3.3V to 2 and 4 pin of PCM2702. When I connected it with USB port of computer, it appeared unknown device in my computer. At this level I remembered the status of PLAYBACK and SSPND, the LED to these two pins was normal.
When I gave 3.3V to 2 and 4 pin of PCM2702, I found the LED to PALYBACK did not brighten but the other SSPND could. I checked it many times and anywhere of the circuit, but I could not find the reason and it¡¯s very strange that the voltage in PLAYBACK pin is 3.3 always. I want to know any guys have good idea for this problem. Thanks. Another thing, I am not very sure if I connected the correct way for the CLOCK OSCILLATOR, I checked the voltage at XTI was 1.78V and XTO was 2.8V, are there correct?
#3 |
pic
#4 |
Schematic?
#5 | |
| Another PCM2702 DAC project. | Dxvideo | Digital Line Level | 1 | 4th March 2009 07:05 AM |
| Problems with my PCM2702 | Mikael Abdellah | Digital Source | 4 | 7th October 2007 10:51 AM |
| Pcm2702 Usb-dac | 00940 | Digital Source | 47 | 24th January 2005 04:36 PM |
| Keces.com PCM2702 | jmar | Digital Source | 23 | 20th February 2004 04:08 PM |
| Pcm2702 Usb Dac | sugano | Digital Source | 9 | 27th May 2003 06:37 AM |
| Page generated in 0.08921 seconds (70.39% PHP - 29.61% MySQL) with 11 queries |
