Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Open Source, Open Architecture!
Old 19th November 2006, 08:26 PM   #181
zenmasterbrian is offline zenmasterbrian  United States
Continuing to read about all the new PC audio activity. It overwhelms me.
Does anyone know of any PC based or digital audio activity in the Santa Clara Valley?
Old 19th November 2006, 09:27 PM   #182
Continuing with David Miles Huber
Talk of MDM, Modular Digital Mutitrack, associated with Tascam and Alesis.
Hard disc recording units from Tascam, Mackie, Yamaha, an d Korg.
Digital audio workstations, DAW, Nuendo Version 2 Media Production System for PC or MAC, by Steinberg, www.steinberg.net
The Audio Interface ( like my idea of having an outside audiophile grade box? Certainly opens the door to it. )
Mackie Spike
www.mackie.com
Universal Audio 2192
www.uaudio.com
M-Audio Delta 1010
www.m_audio.com
Mark of the Unicorn 828, FireWire Interface
www.motu.com
Digidesign Digi 002
www.digidesign.com
Audio Driver Protocols, programs that set standards for allowing data to be communicated between the system's software and hardware. Some common ones are:
WDM, the Windows Driver Model
ASIO, Audio Stream Input/Output, forms the backbone of VST, has variable bit depths and sample rates, multichannel operation, and synchronization. Low latency, high performance, easy setup, and stable audio recording.
MAS, the MOTU Audio System
CoreAudio a Digidesign driver, for Mac OSX.
Latency, buildup of delays
Windows audio driver could be 500mS!!! This throws off performers. ( This is why I was skeptical of any Microsoft based digital audio schemes )
ASIO driver can reduce it down till it is unnoticable. ( I still like the idea of dedicated hardware in the signal path, without dealing with hard disk, user interface, or multitasking )
DAW Controllers, control surfaces
Tascam FW-1884
www.tascam.com
Mackie Control Universal
www.mackie.com
Digidesign Pro Control
www.digidesign.com
These often work by using MIDI System-Exclusive messages.
Soundfile Formats
Wave (.wav) Microsoft Windows format
Broadcast wave (.wav) allows text strings, otherwise as above.
Wave64 (.w64) Sonic Foundry, Inc, now Sony. Similar to above.
Apple AIFF (.aif or .snd) Apple
Sound Designer I and II (.sd and .sd2) Digidesign
To Be Continued
cross posted at Audio Explorations:
http://groups-beta.google.com/group...d0fd6d3020ee74e
Old 20th November 2006, 03:02 AM   #183
Soundfile Sample Rates
32k often used by broadcaseters for 15khz bandwidth, and by those who wish to conserve memory.
44.1k Was the standard because of CD audio. Considered the minimum for pro audio production.
48k was adoped early on as a standard for pro audio. Especially for hardware based digital audio devices.
96k used with 24bit, for DVD ( I believe because the extra data can usually be reduced with lossless compression )
192k, also used with DVD production.
Soundfile Bit Rates
16bits for CD, and considered the minimum for pro audio prodution. A theoretical dynamic range of 97.8dB ( more than analog tape, and way way more than vinyl )
20bits was considered the standare for high resolution. Theoretical dynamic range of 121.8dB
24bits offering theoretical dynamic range of 145.8dB. ( far exceedes human hearing, and any of the analog stuff it has to work with, including ADCs and DAC, and amps and speakers and preamps. )
( digidesign uses 48 bits for internal computations. They have special expensive processing boards for the host PC )
To Be Continued
Old 20th February 2007, 09:51 PM   #184
Still attracted to much of the Tascam gear.
http://www.tascam.com/
http://www.tascam.com/ComputerRecording.html
http://www.tascam.com/Products/US-122l.html
Record two tracks at a time with zero latency; whether you have a PC or a Mac, your song ideas go down in real time, real easy. Its size means you can take it anywhere you take your laptop, yet it's packed with features that make buying it an audio no-brainer. MIDI input and output, high quality mic inputs, 96kHz/24-bit recording (better than CD quality)-all the stuff you'd want without the fluff you wouldn't. The US-122L: the answer to your recording needs. The US-122L is also part of TASCAM's exciting new TNT Bundle
http://www.tascam.com/Products/US-144.html
does more!
http://www.tascam.com/Products/fireone.html
Does 192K/24bit, FireWire
<<Pushing the limits of what an audio interface can be, TASCAM has launched the FireOne - a FireWire Audio Interface with shortcut keys and a weighted & illuminated jog wheel to inspire creative interaction with the artist's music. The FireOne is the first stereo audio interface in its class that records two mic ins and two outs over FireWire at 192kHz/24-bit audio resolution The most unique feature of the unit is its large, weighted, backlit jog wheel, which allows musicians to zip through their song while the backlight provides useful feedback such as a visual metronome.
The FireOne features a pair of mic inputs with phantom power and pad switches. A front panel guitar input allows convenient direct recording of guitar or bass. MIDI input and output are also provided for 16 channels of MIDI. It's the first FireWire interface in its class to record and play at up to 192kHz/24-bit resolution. It includes multitrack recording software, so you'll be set to go right out of the box. In addition to its weighted & backlit jog wheel, the FireOne has transport keys and eight shortcut keys to control functions in most popular DAW applications.
2-in / 2-out FireWire Audio Interface
Up to 192kHz/24-bit audio resolution
Two XLR mic inputs with phantom power and pad
1/4" high impedance input for recording guitar direct
Two 1/4" stereo headphone outputs
Weighted, backlit jog wheel
Transport control keys: rewind, fast-forward, stop, play, record
Headphone output with level control
Eight DAW shortcut keys
Stereo LED meter
MIDI in and out
1/4" Footswitch input
Buss powered through the FireWire connection or use the included power supply
http://www.tascam.com/Products/cubase_le.html
http://www.tascamgiga.com/intro.html
Join Audio Explorations. PM me if you would like a free gmail
account. It makes using google groups easier.
http://groups.google.com/group/audioex_digital
Old 23rd February 2007, 10:33 PM   #185
In terms of actually getting to Open Source, these seem to be the current best things to check out. Thanks to Rosco50 for posting all this.
Demudi
Ubuntu Studio
Mythtv
Old 23rd February 2007, 10:35 PM   #186
http://www.demudi.org/
http://en.wikipedia.org/wiki/DeMuDi
https://wiki.ubuntu.com/UbuntuStudio
Open Source, Open Architecture!Hide this!Advertise here!
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
Open-source DSA project borges Digital Source 8 24th September 2006 07:26 AM
The Viola open architecture of Tom Colangelo rintek Solid State 2 1st July 2004 08:50 PM
