| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I want to learn how to add a BNC Wordclock input to a transport such as a soundcard, CD player or Squeezebox? How would this work? Simply replacing the original crystal oscillator and leading a shielded cable out? Assuming I have a very stable, low-noise clock near my DAC - when I synchronize my sources with this clock, I would dramatically reduce jitter and this would be the perfect choice for a "clean" system as opposed to using ASRC's which are obviously only a poor choice for a low jitter system. Is this correct? Maybe someone can shed some light on this or point me to some threads or reference sources so I can learn more about this. Thanks, Mike |
#2 |
Hello Mike
You'd need a PLL circuit to go from 44.1 KHz to the original crystal frequency. best |
#3 |
Hi.
One alternative is to buy a pro soundcard with wordclock i/o. A very good one is the RME Digi96/8 PAD with the WCM expansion. Another way of implementing the system is to send the master clock directly to the transport, preferably using an optical interconnect. I´m not sure if the standard toslink transmitters and receivers can handle 11.2896 MHz or higher, please check that. The third and best way (IMO): in the DAC, use a spdif tx IC to generate spdif with your clock. You can use any soundcard with spdif i/o as your transport. Or you can slave your cdplayer by adding a spdif rx to recover the 11.2896 MHz (if the MCK of your CDP is 256fs). This last method is how I did it and it works flawlessly. I used optical interconnects and my soundcard is the RME Digi96/8 PST. Best regards, Alexandre |
| wordclock i/o | stef1777 | Digital Source | 0 | 18th February 2005 08:11 PM |
| Adding Digital Inputs ?! | Blue_Max | Digital Source | 3 | 25th January 2005 07:12 PM |
| Adding more inputs for my preamp | bonsai171 | Solid State | 1 | 11th March 2004 10:59 PM |
| Wordclock distribution box-anyone? | Ricren | Digital Source | 0 | 22nd October 2003 09:20 PM |
| Adding a Sub output... sum the two inputs? | PaulHilgeman | Solid State | 9 | 25th February 2003 04:51 PM |
| Page generated in 0.06472 seconds (74.88% PHP - 25.12% MySQL) with 10 queries |
