Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th July 2006, 09:45 AM   #1
Wynand is offline Wynand  South Africa
Wynand's Avatar
Default Is external DSP needed for CS4258?
Hi.
I'm looking for a spdif decoder to give me 6 channels.
I found the CS42528 which will be perfect if I don't need a DSP to run it. I see there are connections for a DSP but all I need is the SPDIF decoder, analog outs and the volume control provided with the chip.
I plan on using an ATMEL ATMEGA32 or ATMEGA128 to control it.
An suggestions?
Old 19th July 2006, 10:19 AM   #2
Default Re: Is external DSP needed for CS4258?
Originally posted by Wynand
Hi.
An suggestions?
You will not need a DSP to run it but you will not be able to use all the dacs at once if you use the internal spdif decoder.
Old 19th July 2006, 10:28 AM   #3
Wynand's Avatar
So if I understand correct....
With a DSP i can get 5.1 audio, without it only stereo?
Old 19th July 2006, 10:36 AM   #4
With a DSP you can get multiple channels and with 3 external SPDIF decoders and some other stuff you can also get multiple channels
Old 19th July 2006, 10:40 AM   #5
Wynand's Avatar
I'm looking to get 5.1 sound from the SPDIF out on the motherboard in my PC.
3 x Stereo Channels won't do.
Is there any other solutions to have a look at?
PS do you get audio DSPs or all they all the same?
Old 19th July 2006, 11:01 AM   #6
Is your MB capable of AC3/DTS over SPDIF. If it is you then need an AC3/DTS decoder. If not, do you have three SPDIF outputs?
Old 19th July 2006, 11:49 AM   #7
Wynand's Avatar
Its only got 1 3-pin header on the motherboard.
I'm going to look at the specs online.
It's a P4M800-M7 A motherboard.
Not sure what chips it has on.
Old 19th July 2006, 12:01 PM   #8
Wynand's Avatar
It uses a ALC655 chipset.
I'm downloading the datasheet now.
Old 19th July 2006, 12:02 PM   #9
Wynand's Avatar
About the AC3/DTS, cant you just send raw PCM over the spdif port?
Old 19th July 2006, 12:40 PM   #10
Raw decoded data is sent as pairs so 5.1 would need 3 SPDIF pairs. Undecoded multichannel AC3/DTS can be sent over one SPDIF pair.
PCI I2S External NOS DAC Bidule Digital Source 10 3rd August 2008 04:15 PM
External switched capacitor integrator (clear saa7323 datasheet needed) ash_dac Digital Source 6 7th May 2006 11:21 PM
DEQ2496 and external dac ? then_dude Digital Source 0 20th October 2005 08:17 PM
External PSU for preamp Tyimo Power Supplies 1 15th May 2005 06:54 PM
External CDP PSU recommendations mcai7et2 Digital Source 2 10th July 2003 01:15 PM
Page generated in 0.09128 seconds (81.41% PHP - 18.59% MySQL) with 10 queries
