Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Audio DAC as signal generator (Need DC output).
Old 6th December 2002, 03:43 PM   #21
Pjotr is offline Pjotr
Pjotr's Avatar
Hi Phil,
Whatever you chose, to get a S/N better than 120 dB will be very difficult. Also noise entering your cabling is very difficult to avoid.
As an alternative for a PCI card you can look at the various USB cards.
If you Google at analog+conversion+pci a load of cards come along. But al professional measurement cards ar no better than 16 bit.
Attached the noise performance of the AD part of my audio card at no input for both channels (8 kHz sample rate). You will clearly see 1/f noise. This is something you cannot avoid due to the properties of semiconductors. The PM1704 is not different.
Old 7th December 2002, 01:05 AM   #22
jackinnj is offline jackinnj  United States
jackinnj's Avatar
I'm not really certain the exact magnitude of the signal and errors you want to measure and replicate as I've seen 10mV, and 0.045uV quoted in these postings, quite an extreme. At the bottom end even a small movement of the cable (if it's not a really low noise cable) can cause the movement of electrons !
It really sounds like a Keithley Instruments, nanovolt source type problem -- you can spend a couple kilobucks and buy one of their units with a 488 type interface.
Audio DAC as signal generator (Need DC output).Hide this!Advertise here!
Why TAS3103 no audio signal output? KevinChen Digital Source 6 25th February 2011 01:32 PM
Wanted: one audio signal generator sdaudio2 Swap Meet 0 6th May 2007 01:04 PM
FS: BK Precision 3001 Handheld audio signal generator davidhs Swap Meet 3 6th May 2007 06:18 AM
Class Evolution-Modulating SMPS output to track audio signal vectorplane Power Supplies 42 13th January 2007 12:33 PM
