| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I want to swap out the ops that are in there right now. They are super low end/grade ops (LF35N)
http://www.chipcatalog.com/National/LF353N.htm It is a very low grade op...one of the worst available. I would like to replace this one with either of these: http://www.chipcatalog.com/Linear/LT1362.htm OR http://www.chipcatalog.com/TI/THS4032.htm Would either of these others work as drop-in type replacements where NO modifying is necessary to keep the amp working properly??? Thanks all!!! |
#2 |
Hi
I suggest OPA2134 best |
#3 |
I suggest Lt1469,sounds nice!
Regards Åke |
#4 | |
What others have you played around with in amplifiers and compared the LT1469 with? Thanks for the recommendation. I'm looking into it now. Regards! |
#5 |
Read this thread its all about trying opamps
http://166.90.205.111/forums/showthread.php?t=161941 I tried the THS4031 on this amp and it sounds nice just like AD8610 but when Itried the Lt1469 it has a openess and detail that is hard to beat. Suggest ju read the thread.
Regards Åke |
#6 | |
From what others have said, the THS4031/THS4032 is substantially better than the AD8610/AD8620 types. I saw you tweaked your amp quite a bit to achieve the sound with the different ops. Did you ever manage to just do a simple swap in/out using the existing circuitry and using all the ops you have tried? I see you mentioned four ops on head hi-fi, but didn't see any mentioning of the THS ops. Thanks again for your recommendation. I don't think it hurts to try them especially since they are dip style if I am not mistaken. I would like to hear more of your thoughts on the THS based op and as well, the LT1360 you seemed to mention quickly, but didn't seem to appeal to you? LT1360 is another that is supposed to be better than the ones you mentioned in the head-hifi thread. I know we all have our feelings about different ops. What I am looking for, primarily, in an op, is one that will be able to give as transparent/see-through sound as is possible...something that can reveal as much of the recording as is possible. I think this op you mention can easily beat what I am using now, but still want to consider some others (not the 827 or other OPA types, though) ![]() Thanks again!!! |
#7 | ||||
I saw you tweaked your amp quite a bit to achieve the sound with the different ops. Did you ever manage to just do a simple swap in/out using the existing circuitry and using all the ops you have tried? Yes it was the offset I was trying to get as low as possible,It would have worked whitout tweaking at all,but when I changet to the Smp bufferts I liked the sound even more. Quote:
Regards Åke |
| For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! | opc | Swap Meet | 23 | 2nd November 2009 05:04 PM |
| Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest | mbcouple | Swap Meet | 2 | 27th October 2008 10:27 PM |
| ANY "High-Perf" SIL op-amps to replace NJM5532 | homemade | Parts | 2 | 13th December 2006 03:41 AM |
| SMPS for diy audio amps and multi-channel diy amps (and their power supplies) | tlparker | Solid State | 18 | 31st August 2006 10:39 AM |
| HDAM module to replace op amps | rabbitz | Digital Source | 1 | 24th April 2006 08:15 AM |
| Page generated in 0.10272 seconds (79.04% PHP - 20.96% MySQL) with 10 queries |
