Philips CDM4 laser pick-up
Hi does anyone know what the different between CDM4 and CDM4/11, CDM4/19 and CDM4/25. Are they all the same or totally different. Thank you.
CDM4/11 has Hall motor, CDM4/19 brush motor, and the chasiss are completely different, look at http://www.ersatzteil.justone-schnepel.de/
The arms with laserhead are probably compatible. There are lengthy discussions on these in this forum. |
the /number indicates their speed.
WHAT???
do you mean that the motors spin at different RPM and that the gears have to be different?
I thought that the /X was a revision number |
Hi Bricolo
Don't believe everything you read here. Your thinking is correct. If we believe this "speed" thing - it would mean that a CDM4/31 is almost three times faster than a CDM4/11.................but they are interchangeable............. The /X is the revision number! |
| All times are GMT. The time now is 01:24 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
