| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
For an infrared remote controller, does someone have a quick and dirty circuit to add a 38kHz carrier to a digital signal (such that a digital "1" transmits the carrier, and a digital "0" transmits nothing)?
#2 |
D flip-flop
#3 |
I think this would do the trick
Make sure that you either use a darlington transistor with normal diodes or a normal transistor with schottkey diodes. Regards, simon |
#4 |
Thank you very much!
#5 |
That solution requries that the carrier be supplied separately, which is great if the carrier is already available. One trick to both generate the carrier and modulate it is to use a 555 timer, configured to output 38 kHz with 50% duty cycle, and use its reset pin to modulate the carrier with the digital signal. When reset is asserted, the 555 stops oscillating, and when it is deasserted, it starts again. The output of the 555 is sent to the IR leds, and since the 555 has high drive current you can usually drive them directly.
#6 | |
Though in a 3.3V or 5V land, use a TLC555 timer instead of a NE555. |
| fullbridge carrier class d ideas | Tekko | Class D | 12 | 25th March 2011 08:00 PM |
| people carrier sounds | NED 209 | Car Audio | 3 | 31st December 2008 12:11 AM |
| Tube sockets without the ceramic carrier. | ashok | Tubes / Valves | 5 | 16th May 2007 07:24 AM |
| Carrier Current AM Radio transmission | akersa | Parts | 2 | 13th April 2003 03:57 PM |
