Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th July 2006, 07:56 AM   #1
sangram is offline sangram  India
Default Delta 66 outputs
Hi
Don't know if this should be in Digital, but here goes.
My Delta 66 balanced outputs are acting funny. The hot signal is fine with 0 offset and a strong level, but the cold signal has no or very little signal and a very high offset - about 20 mV.
The card was picked up used, and for a long time was run using unbalanced inputs on other equipment, with the cold lead shorted to the shield. I continued till I got an amp with balanced inputs, and now it runs in balanced mode but it's still not fixed.
Would this kind of operation damage the opamps on the cold signal output? (5532 SOIC types) Or is this normal with the Deltas? Rod Elliot has described a 'balanced' scheme on his website which just lifts the cold signal from the signal ground, to create a pseudo balanced operation mode. Maybe this is what it is?
Didn't realise how bad it was till I got my new 1212M, which has a much hotter overall signal (quality aside) and a pure balanced output.
Balanced outputs used as inverting & Non-inverting preamplier outputs gni Solid State 4 19th September 2008 03:25 AM
Edcor outputs? kegger Tubes / Valves 4 3rd February 2007 04:35 PM
8V on outputs dome406 Chip Amps 3 11th September 2005 03:16 PM
how low is 'low DC' on SOZ outputs? psarin Pass Labs 8 8th March 2002 01:39 PM
Page generated in 0.05241 seconds (70.06% PHP - 29.94% MySQL) with 10 queries
