Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd December 2002, 01:37 PM   #1
Default First DAC project ,TDA1541 current output
My first DAC project is the Adagio by Thorsten. I have measured
everything in it: - the dc voltages are working well, - the CS8412
outputs Fsync, SCK, SDATA are as on Data Sheet, - SDATA
is changing together with the music.
I measure with an oscilloscope.
The trouble is: With a (raised for the measuring) 300 ohm I/V resistor I can measure a continous - 2,7 mA current and can not
see any signal on it.
I see only the noise on it generated by the digital ICs, which can be seen on any wire in the circuit
The DAC chip was soldered in, while I debugged the circuit( the TL431 pins were used incorrectly).
Maybe I damaged it ( but what about the - 2,7 mA)?
I need your help, how to go on?
George
Old 4th December 2002, 01:34 AM   #2
Default Could be mode madness
If your getting valid lock on receiver - Pin 28 goes low - with signal lock you will see clocks/data etc... and the dac should have 2-3ma and 3-4 volts dc on it's output (it's been a long time since I've actually measured 1541s) that sounds "normal". But if your mode select isn't right you'll get nothing/noise or both, and you will see signal/clks etc on the inputs, but the dac won't pass. I use the following mode 'code' with a 8412 and a TDA1543 (I2S) Pin 24 HIGH and 23, 18, 17 LOW and 16 (select) HIGH. Works for me
Old 4th December 2002, 02:01 AM   #3
Default Interesting
Found an "adagio" schematic online - shows 8412 and 1541 - BUT the mode is tied for 16 bits LSBJ on the schematic - not I2S.. won't work at all, ever. Tie 24/23/18 and 17 as I described above and you'll be cooking with gas.
Old 4th December 2002, 07:16 AM   #4
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb TDA1541 to CS8412
Hi See also
http://www.audioasylum.com/audio/twe...ges/43179.html
and
http://db.audioasylum.com/cgi/m.pl?f...en&r=&session=
Old 4th December 2002, 08:10 AM   #5
Hi Scottnixon, Elso!
Many thanks for your quick help, probably I will fix the problem this evening .
George
Old 5th December 2002, 09:58 AM   #6
Default problem fixed
Thanks again, the problem was fixed with your help, my first DAC is working now.
George
Old 5th December 2002, 04:12 PM   #7
hifiwolf's Avatar
Default Re: First DAC project ,TDA1541 current output
George
Hello,
i am today by first step to DAC ( collect informatoon and parts ), what you are just madea and finished.
Please send me your comment , how you like the results of this DAC. Whay you aren't made a DAC with the newest ships--BB1704 etc....
hifiwolf
Old 6th December 2002, 10:33 AM   #8
Default More help needed
Hi Hifiwolf!
I am a beginner in the DAC world, so I wanted to choose a project, which was realized with good result.
So I choosed the "ADAGIO" DAC made by Thorsten Loesch.
It is simple, no oversampling, no digital filtering, and has
a tube output.
You can see and read about it :
http://www.fortunecity.com/rivendell...io/Adagio.html
The schematic has some mistakes, and the TDA1541 is a rare bird,
but this road is used by others too , with success:
http://www.soundstage.com/revequip/zanden_5000.htm
I have just finished it with the help of the kind great guys here.
I connected it to my balanced OTL amplifier without preamp:
The bass and treble extended, more dinamic , the music is more
involving. So the DAC is promising, but one problem remained.
There is some hum and buzz, which is generated by the the tube
output of the DAC , and I could not solve it yet.
To make a try I connected the DAC to my balanced preamp from just the seconder winding of the transformer (without the passive filter and without the tube output ) and it sounded equally good as before, but more output voltage and so the tube output stage is needed.
More impressions later.
Scottnixon, Elso, ....!
I have run out of thoughts to solve the above mentioned hum-
buzz of the tube output stage. Any proposal?
Or I have to modify to a new balanced symmetrical tube output with better CMNR?
Thanks in advance
George
Old 6th December 2002, 04:30 PM   #9
hifiwolf's Avatar
Default Re: More help needed
May be you must something with grounding to do, or with wires lenghth...
hifiwolf
Improvements to TDA1541 dac output stage? sharpi31 Digital Line Level 15 9th February 2009 07:53 AM
Current Project ptah Solid State 34 11th December 2006 03:06 PM
Yet another output stage for TDA1541 mevangel Digital Source 6 21st November 2004 08:21 PM
TDA1541 + I/V Output Transformer mrstone Digital Source 10 17th April 2004 02:19 AM
How many TDA1541(A) in parallel without output baffer? iklari14 Digital Source 0 7th August 2003 11:34 AM
Page generated in 0.10488 seconds (78.12% PHP - 21.88% MySQL) with 10 queries
