| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
it,s the 2nd project I modified it uses the philips 1541 chip non oversampling.valves 6c45pi output caps mundorf silver supreme the power supply is dual mono using awa 5V4 rectiiers its choke,cap,double choke ,cap the chassis is 2.5mm copper a case needs to be made for it .the orignal dac was made by Audiocentric & the new power supply was designed by Black Art Audio who also made the transformers and chokes .
![]() ![]() the interconnects I made using products from AudioConsulting Serge was very helpfull. ![]() the black box is a 4500va isolation transformer made buy Black Art Audio a lot better than the Hydra I found . ![]() cheers Malcolm. |
#2 |
Malcolm,
I fixed that one image link. Thanks for sharing this exceptionally good-looking piece of work. /Hugo |
#3 |
#4 |
ya that is nice work, i want one
#5 |
I need to change the I/V resistor from 50ohm to 34ohm or make an inductor @ .33mhy with 34ohm resistance.
| new to the forum pre-amp | 56oval | Tubes / Valves | 2 | 25th June 2006 02:15 PM |
| Bug in forum? | roibm | Forum Problems | 6 | 6th May 2004 01:31 PM |
| French people on the forum ? Des Français sur le forum ? | frankie | Introductions | 19 | 30th December 2002 09:40 PM |
| a new forum | trip-wire | Everything Else | 3 | 26th December 2002 06:32 PM |
| Page generated in 0.07692 seconds (71.67% PHP - 28.33% MySQL) with 10 queries |
