| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello,
i will make something good DAC for my tube amp. and will ask some help/ideas from the best with long experience DIY makers. 1. Is the adagio DAC project with one TDA 1541 good enough ? 2. If yes please let me know if somebody have and can send me the PCB layout ? 3. If not --please let me know some another good alternative for non-os dac ... 4. What kind of type of decoupling Capacitors ( o,1 mf) are the best for this DAC (http://www.fortunecity.com/rivendell...io/Adagio.html ) Are somebody tested different types of good audio caps by TDA1541 project ? I write next possible types, about what i think: --- jensen oil- aluminium foil-paper- or some another oil capacitor wit aluminium foil ----Mundorf M-cap superme or MCAP ZN ----Hovland caps ----Kimber caps Sorry for my englich, but seriously will make one good DIY DAC ( i hope that non OS is good for me ...?!) hifiwolf |
#2 |
From the caps youy mentioned Hovland would be my choice. I was testing Jensen copper foil paper in oil type, but was not impress by them. Although they have body and musicality, they lack in detail. I had to bypass them with siver foil Ultracaps to get what I wanted. OTOH hovlands posses all around good sound and it's hard to be disappointed by them. Some people recommend Auricaps, but I didn't try them yet.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 |
Hifiwolf,
i´ve been in contact with Thorsten Loesch on this specific DAC for a while. He himself says that tinfoil caps are highly recommended. He did use some KS/tinfoil from Philips. But that is old stock and hardly available. The alternative would be hovland maybe, so he did recommend Audyn or Mundorf tinfoils; they are somewhat the Hovland equivalent in Europe, as is solen´s tinfoil said to be.He also did use sanyo oscons, about 15µF on the msb pins. Discussing wih him made it look like he had thought it out;-) BTW according to him the greatest fault you can do is use a wet string, excuse me i meant the jensen caps, there .. Philipp |
#4 |
Do you have experience with the the output stage by 1541 chip:
--tube output --opamp output --transformer output I have not jet seen/find this projekt with transformer output, but some of DIY makers find transformer the best ?? |
#5 |
Transfromers:
Passive 25 ohms & Sowther 1:18.7, nice, but lacking dynamics, bass, low output volume Amplimo TM3; no way... Capacitors: In CD players with 14 ceramic caps, replacing them with WIMA MKS 100n is very worthwhile. "Better" caps are almost impossible to fit in existing players. I've been using 68n MKS parallel with 10n KP on LSB and 15u Oscons on the MSB. Google search of "TDA1541A-S1" gives all you want.
Rudolf Broertjes |
#6 |
Banned
Hi Rudolf & infinite baffle,
I made a PCB for the TDA1541 with place for 1µF decoupling caps. I tried Polyester, Polycarbonate and Polypropylene. The latter did not fit well but I was able to hear the difference. In my experience the type of cap is not utterly important. I tried also different values. I found the 1µf a optimum value. 15µF is absolutely overkill. I am not fond of tinfoill caps anywhere in my equipment and that is not the first time I disagree with Thorsten... ............![]()
#7 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#8 |
Hello,
it is here in my country not far one piece TDA 1541-S1, what i can simple get ---and it is very complicated to find differences between older and newer production--only i find,that the 1541 is a old good -with no big risk thing... so i have read in a lot of forums... and home pages... The antique things are for one audiophile fun alltime very good staff---all good things --vinyl, tubes, capacitors, loudspeakers, resistors.... all these things are only good-- if are "RARE"---it is the thing, of course a matter of taste but i now belive to this staff. For me is important analog and with the big spirit voice--but no voice with the digital image.. it is not simple to explain the thing... Do you have real alternative offer for the TDA 1541, what i can look ? best regards hifiwolf |
#9 | |
#10 |
I admit there is one problem: Most of the chips are SMD and 0,63 mm pitch......
| Quality capacitors without breaking the bank | philb | Parts | 4 | 8th January 2006 09:06 PM |
| Quality Capacitors in UK | iamwhoiam | Parts | 2 | 27th January 2005 07:18 AM |
| High Quality Capacitors for Active Crossover | macka | Parts | 0 | 25th March 2004 07:57 PM |
| High quality capacitors, resistors | Vortex | Parts | 2 | 6th March 2004 03:34 AM |
| Quality if Xicon Capacitors | PaulHilgeman | Parts | 1 | 20th February 2003 04:37 AM |
| Page generated in 0.10389 seconds (88.49% PHP - 11.51% MySQL) with 11 queries |
