Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th June 2006, 03:32 AM   #1
pwan is offline pwan  United Kingdom
Default First DAC - pls advise.
I am new to digital DIY. I'd like to do a DAC (to use with P101 amp with passive pre) but seems being overwhelmed & don't know where to start.
If all parts will be order from digikey, could you recommend a couple of good & simple DAC to start with (as my first DAC project)? Thank you.
Old 19th June 2006, 06:19 AM   #2
jleaman is offline jleaman  Canada
Send a message via AIM to jleaman Send a message via MSN to jleaman Send a message via Skype™ to jleaman
Passive pre amps are all ways good to use.. You will have to use a buffer tho on this Dac.. I run all my stuff passivly its much nicer BUT it takes time to setup.
Baby Danika, Born January 20th 1:54am..
http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect..
Old 19th June 2006, 07:34 AM   #3
Any real good advice on this because I am very interested too.
Old 19th June 2006, 08:04 AM   #4
Thanks for your comment.
Many suggests me to start with NOS DAC with TDA1543 but I cannot find it on digikey or mouser.
What other DAC circuit do you recommend to go for?
Any one know where the CS8412 and the old TDA1543 can be ordered online?
Thanks!
Old 19th June 2006, 09:28 AM   #5
georgehifi's Avatar
Send a message via MSN to georgehifi
If you like passive pre's you should build what was my closely guarded secrete, till it was sucked out of me, on the Solid State forum, now it's there for all to enjoy.
Lightspeed Attenuator a new passive preamp
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 19th June 2006, 10:53 AM   #6
Default Re: First DAC - pls advise.
My latest project - DAC + headphone amp
Old 20th June 2006, 01:59 AM   #7
Thanks you all for your comment and suggestion!
Old 20th June 2006, 02:42 AM   #8
Cheers George
I have this thread added also, I like a plane jane nice pot. Im thinking I might try a DACT or a welborn labs Volume pot. I ditched my relay based one as the relays were not making contact at certain levels and i was getting annoyed.
Need advise on this amp... JojoD818 Solid State 20 18th December 2010 11:14 AM
Please advise WunHungLo Multi-Way 4 28th June 2004 11:38 PM
Page generated in 0.09014 seconds (78.70% PHP - 21.30% MySQL) with 10 queries
