| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I'm thinking about making a small production series of my DAC, embedding it in a box with a CD transport as well.
The CD-Pro2 looks like it is getting good reviews. Is it easy to get by this (or similar drives)? Perhaps more importantly, I plan to generate MCLK on my DAC board and send it down to the transport. But some documentation I found on the CD-Pro2 states that the MCLK is an output signal. So, what setup is recomended when I want MCLK to be an input to the CD drive? I am completely new to working with cd transports but know both mechanics, I2S and MCU programming. Hints and tips are much welcome! Cheers, Børge |
#2 | |
You would have to remove the onboard oscillator/resonator. |
#3 | |
Do you plan to create an open system, i.e. one that will work with other devices that have a reference clock output or a closed system like the Sony Twinlink? |
#4 |
It is a closed system, I guess, because this has to do with the internal wiring inside a CD player.
I plan to use Guido's clock circuit on a board where I'm in charge of power supply, decoupling, and ground layout. Not the oscillator on the CD transport. I'm looking at the L1210/65. I guess that supplying the clock from outside should be doable, I just have to mod each one. Anyone having experience modding this transport? Cheers, Børge |
| DIY transport w/ CDROM drive vs player as transport | dw1narso | Digital Source | 6 | 2nd September 2011 06:15 AM |
| Is mclk fs the same for all formats in a multiformat player? | poolorpond | Digital Source | 0 | 27th July 2006 03:01 PM |
| New CD 63 Transport | leeo666 | Parts | 0 | 22nd June 2006 12:05 AM |
| CD transport | audionut | Digital Source | 3 | 24th September 2005 03:44 PM |
| MCLK (22/24MHz) signal transfering. Distance 25cm. | Dalius | Digital Source | 8 | 22nd April 2004 10:30 AM |
| Page generated in 0.08471 seconds (73.58% PHP - 26.42% MySQL) with 10 queries |
