Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th June 2006, 09:41 AM   #1
PinkPanther-2's Avatar
Default How can a CD be adjusted by eye pattern?
I have a Philips CD482 (CDM 4/19, SAA 7310, 7220, TDA1543(>2*TDA1541 +OPA627U+AD829). But I have no service manual and will adjust the servo part. I know it's possible to adjust the focus and laser current (carefuly!) by eye pattern on the screen. So I have also a Tectronix 2225 (50MHz) i will be thankful for some hints for such a procedure.
Old 10th June 2006, 04:14 AM   #2
Adjust the eye pattern on your scope so that it has the highest and clearest signal. I know that some design; the scope gnd conncetion should be connected to Vref rather than the gnd/-ve of the CDP power supply.
Hope this helps.
Old 12th June 2006, 07:32 AM   #3
Thank you vt4c!
This is very valuable information. I find also a very extensive information about CD repair here:
http://www.repairfaq.org/REPAIR/F_cdfaq.html[COLOR=blue]
Pattern around tweeter... Godzilla Full Range 6 9th December 2008 12:17 PM
PCB pattern for 100W Amp r_s_dhar Solid State 49 20th August 2004 12:05 PM
Can I post this PCB pattern for the 25W Amp r_s_dhar Solid State 2 15th July 2003 06:03 PM
Adjusted bias for parallel output Paulr Solid State 10 7th July 2003 04:21 PM
Page generated in 0.06723 seconds (76.57% PHP - 23.43% MySQL) with 10 queries
