Cd player beginning to skip.... :( - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th November 2002, 12:25 PM   #11
Banned
Send a message via MSN to SkinnyBoy
" 14.8) Audio whine (not from speakers) and/or muddy sound with Sony CD players
Generally, the only symptom is a CD players that sounds unhappy - there are
no audio or tracking problems. However, in severe cases, there may also be
audio degradation described as "muddy sound".
(No doubt, a non-Sony approved weight would work equally well for the solution
below.)
(From: Lance Edmonds (lanceedmonds@xtra.co.nz)).
The whine problem usually occurs with KSS240A and KSS213A optical pickups, and
is caused by a mechanical resonance. There are at least 2 service bulletins
describing the fault and the cure.
Sony sells a special weight to fit to the pickup, and also a felt pad to add
to the bottom of the top clamp assembly. Both these items cure this problem.
Some machines may only require the weight.
In rare circumstances the resonance can interfere with the tracking/focus
servos enough to cause skipping. Usually the problem is not easily repeated,
however certain light weight disc's may trigger the problem repeatably.
Note that the resonance usually only occurs on the first few tracks if at all,
and some disc's will play with the problem never showing up. Seems to be a
disc weight/thickness/density problem.
Contact your official Sony service office for the part numbers etc."
Old 29th November 2002, 12:27 PM   #12
diyAudio Moderator Emeritus
jean-paul's Avatar
Default exceptions confirm the rule
What has this to do with laser current ?
It's only audio. Member of the non modular PCB design committee
Old 29th November 2002, 12:29 PM   #13
Banned
Nothing, but it may be what the problem actually is...
Old 29th November 2002, 12:31 PM   #14
jean-paul's Avatar
OK, thanks anyhow for the info. Did not know this about Sony lasers. I am used to Philips ones.
Saved the info just in case
Old 29th November 2002, 12:32 PM   #15
Banned
I just searched on google... I don't even know what it means.. lol
Old 29th November 2002, 12:33 PM   #16
jean-paul's Avatar
Wink you're not serious are you ?
Before I am being accused of threadjacking:
Duo, does the info Skinnyboy supplied apply to the laser of your Sony player ?
If not, what about buying a new laser ? They are not that expensive nowadays. Replacing them is not very hard to do.
Old 29th November 2002, 01:42 PM   #17
Electrons are yellow and more is better!
peranders's Avatar
BTW:
I got from a friend an Yamaha CDX-810 with a worn out "press plate" or what you call it. A mechanism which presses the CD towards the platter. The upper part has a single ball point bearing. When the press plate has got a pit from the steal ball, the laser starts to dance "jenka". If you make the press plate press harder, it won't help.
Have you checked the mechanism for holding the CD tight?
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 29th November 2002, 01:56 PM   #18
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
I have checked that the cd is held in firmly, it's actually quite solid for a magnetic holder.
I do see what you mean about current adjustments, I had a SS laser pointer that began do die after a while, it just got weaker and weaker.
First I'll attempt to clean out the whole optics of the thing, I think I got some bad dust in there cause I was stupid and sanded some wood near my listening room and made a big cloud of dust.
I found that cleaning the outer surface of the lens helped quite a bit, but I'll clean the rest before I make any adjustments.
I have a scope, a few for that matter. I'm quite electronically capable so if you guys know how to use the scope to make adjustments can you tell me? I'd like to make sure its calibration is good anyhow...
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 29th November 2002, 02:10 PM   #19
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
This thread provides some good info on lasers and related mechanisms: Philips CDM-1
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 29th November 2002, 03:02 PM   #20
Duo's Avatar
Well, I couldn't really find the info I need in there. I have to find out how to connect the scope first. I have no idea where to tap on so I can see the proper waves. I don't really know anything about how the waves should look or anything, so I need a bit of explanation if anybody can help with that...
Why does my CDM4 skip? S.Spielbergo Digital Source 10 4th March 2009 10:51 AM
sony cdp-c305 cd changer skip sdiesel Everything Else 2 10th October 2008 12:17 PM
Technics SL-23 makes records skip on inner tracks for apparently no reason MrFuqua Analogue Source 4 12th September 2004 06:31 AM
Skip 805, what can I do with 6HS5? Sch3mat1c Tubes / Valves 5 22nd October 2003 01:35 AM
Philips CD720 (CDM12.1) beginning to skip capslock Digital Source 22 26th March 2003 07:54 AM
Copyright ©1999-2017 diyAudio
