staked DAC chips ?? - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th November 2002, 12:17 AM   #1
Default staked DAC chips ??
Ive search around and seen couple of coments about stacking DAC chips..!!??!!..
Would having a 2 or more staked DAC (one on top of each other ?) chips make a improvement in the sound ??
m.
Old 29th November 2002, 12:30 AM   #2
diyAudio Moderator Emeritus
jean-paul's Avatar
Default To stack or not to stack, that's the question
Depends on the chip itself if it is possible technically. Common ( but mostly temporarely ) practice with TDA1543's and I even saw a cd player once with stacked PCM63's. Kusonoki, the guy that started this non os thing, tried it but in his later designs he used only one TDA1543.If you have a DAC or cd player with these chips you can try it.
My advise ( for what it's worth ) : it's a waste of time and money.
The chips are NOT designed for this I would like to add.
It has some positive effects ( bass slam ) but the negative ( high tones were better before ) overrule them.
Oh oh, I have to run now
It's only audio. Member of the non modular PCB design committee
Old 29th November 2002, 01:10 AM   #3
What are the conditions that make the DAC eligible to be stacked??
My player has PCM66 I can not find any references about the chip anywhere so i have no idea how good the chip is supposed to perform...and since i have a extra chip i though to maybe go ahead and try....
m.
Old 29th November 2002, 01:26 AM   #4
jean-paul's Avatar
Are you sure that these are PCM66 ? I know PCM56,58,63,67,69 but 66 I can't find in my pile of BB datasheets
Please see this thread what Elso has to say about paralleling DAC chips: Cheap DIY DAC
Old 29th November 2002, 01:36 AM   #5
yep...they are: bb pcm66p ..the player is a old sony portable..one of the top of the line....i even have another sony player the same age and it has 2 of them !!!..so it seems it is not a 1 model only chip..
look here...
http://www.omr-lab.com/D-Z555.shtml (this is the one with 2 ) i have that same model and it sounds very good (for a portable...)
hope this helps.....
Old 29th November 2002, 01:45 AM   #6
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I stacked 2 PCM 1704 K in my DAC. Initially I didn't like the effect, but after shielding the chips with copper foil and shielding digital and analog parts of the board the was improvement. More info here: Parallel DACs
www.audiosector.com
Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it. - JC
Old 29th November 2002, 02:02 AM   #7
thank you Peter for the link, that is the kind of info i was looking for..(but i search for stacked instead of paralel... )
if anyone has info about the pcm66..please let me know...
thank you all....
m.
dac chips kiwi88 Digital Line Level 2 5th August 2009 03:25 PM
Any 24 bit NOS DAC chips? neutron7 Digital Source 6 29th October 2006 09:48 AM
nte chips odysseybmx414 Chip Amps 1 29th September 2005 09:30 PM
Chips for Chumps aka "Intelligent Chips" jackinnj Solid State 0 15th April 2005 01:37 AM
Stk-chips Mikelmonster Chip Amps 2 27th May 2004 06:22 AM
Copyright 1999-2017 diyAudio
