| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I'm looking at getting a Squeezbox 3 and performing some mods on it. I've been reading various threads over at the slimdevices andaudiocircles forums but nobody seems to give any specifics on actual modifications. So far I've not come across any photos showing SB3 internals.
Does anybody here have any advice on what mods I should an shouldn't do? I have a friend who is very competent with smd soldering so that isn't a prob. Here is a list of mods I've complied so far. Any comments? 1. Swap DAC for KE version (Red-wine / Bolder) 2. Internal power supply caps: - Dac Power: Panasonic/BlackGate Nx (Bolder) - Dac Power: BlackGate NX-Hi-Q (RedWine) - input power: Panasonic/BlackGate Nx (Bolder) 3. OPAMP: - Remove (Bolder) - causes low rms o/p and phase inversion - Replace with BurrBrown OPA2604 (Red Wine) - adds Punch 4. Output Caps: - BlackGate NX-Hi-Q from opamp out to RCA (RedWine) - BlackGate N with Sonicap Gen 2 bypass direct from DAC to RCA (bolder) 5. Upgrade RCAs (Red-wine / Bolder) 6. 5V external linear (Red-wine / Bolder) 7. Remove 14V feed, replace with external 12V (RedWine) (power supply to DAC/OpAmp) 8. Higher 5V input cap (low ESR) http://forums.slimdevices.com/showthread.php?t=16329 9. Disable 12.28MHz oscillator (only needed for low bitRate internet Radio) 10. Add vibration damping material to oscillator Cheers Al |
#2 |
Did you check out the DIY forum over there? There are a couple of threads on modding the SB3:
http://forums.slimdevices.com/showthread.php?t=23687 http://forums.slimdevices.com/showthread.php?t=23473 |
#3 | |
And there is this older thread that describes what I did: http://forums.slimdevices.com/showthread.php?t=19822 ---Gary |
#4 |
Gary, I think your totally right about removing the op amp (from reading your posts). The data sheet for PCM1748 says Vout is 0.66*Vcc or 3.3V p-p, which is more than enough.
Have you considered tapping the I2S lines and using them with an external DAC? I'm wondering if anyone's done that, as it seems like that would be a nice solution. |
#5 | |
I_F |
#6 |
Yeah, I have. I read p. 22-23 of the PCM1748 data sheet.
#7 | |
diyAudio Moderator Emeritus
#8 |
Thanks for the replies. Very interesting and helpful links.
At the mo my planned mods are : decent regulated 5V supply remove opamp and replace coupling caps before new RCAs. change power supply caps for panasonic FCs or blackgates with same values as originals swap DAC to KE version Is there anything else I should try? Has anybody tried replacing the 14V dac supply with an external regulated version? I was also considering using a NOS dac with the modded SB3. Something like a DDDAC or Monica 2. Anybody tried this? Any comments on how these DACs compare to a modded SB3 (i.e. is it worth the extra expense)? Al |
#9 |
Yep. I saw that too.
Here is a link to Ken's post. http://www.audioasylum.com/forums/pc...ges/12621.html |
#10 |
Who the hell is Ken?
I meant John! Oops |
| Wtb: Squeezebox 2 | rhysh | Swap Meet | 5 | 19th February 2009 03:29 PM |
| FS: Squeezebox 2 (wired) | loddie | Swap Meet | 0 | 8th January 2008 04:22 AM |
| Squeezebox 3 UK (EU?) | jimbo1968 | Group Buys | 4 | 4th November 2006 11:05 AM |
| Squeezebox 3 | I_Forgot | Digital Source | 0 | 3rd January 2006 04:16 PM |
| Modding Slimdevices Squeezebox | Adrian | Digital Source | 1 | 12th October 2004 10:44 PM |
| Page generated in 0.09811 seconds (87.94% PHP - 12.06% MySQL) with 10 queries |
