Eliminating jitter "completely" - Benchmark DAC1 approach - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th April 2005, 10:59 AM   #21
PHEONIX is offline PHEONIX  Australia
Default BENCHMARK DAC1
Hello
There seems to be a mistake here that needs correction, the DAC1 uses 28.322Mhz clock and not 25Mhz. If technical things are to be discussed we should facts straight.
Benchmark DAC1 should be looked at as a whole thing and not reduced just to its bare bone chips. This unit is very competently put together unit, with a good PCB design. Thats why it works well.
Arhur Rappos
Old 11th April 2005, 12:16 PM   #22
Previously: Kuei Yang Wang
Default Re: BENCHMARK DAC1
Konnichiwa,
That would be good. Now, IF the DAC1 used a 28.322MHz Crystal the ASRC and DAC would work at an integer divisor of either 128, 256 or 384 giving either 221.2656KHz, 110.6328KHz or 73.7552KHz. The one frequency it could NOT work at, with a 28.322MHz X-Tal is the claimed (in Benchmarks Literature) constant 97.65625 kHz.
So, it would indeed be good that if wish to discuss technical things we should get our facts straight. Either Benchmark has theirs wrong or you yours.
I believe that is what was done here, to consider the whole operation and interaction of the various sections of the DAC and the result as a whole.
Sayonara
Old 11th April 2005, 12:56 PM   #23
Default DAC1
Hello Kuei Yang Wang
I have in my possesion a DAC1, I just read off the frequency written on the clock , which reads 28.322Mhz (clock frequency) ECS-2100(MANUFACTURES series no).
Arthur Rappos.
Old 11th April 2005, 01:04 PM   #24
Default Re: Re: Eliminating jitter "completely" - Benchmark DAC1 approach
"The DAC does not accept 192KHz input."
The DAC1 does accept 192Khz input it then down converts this to 96Khz.
Arthur
Old 11th April 2005, 02:30 PM   #25
Default Re: Re: Re: Eliminating jitter "completely" - Benchmark DAC1 approach
Konnichiwa,
Then the in your posession DAC1 does not operate according to the claims of Benchmark Media.
I find it interesting insofar as this would shift the sample rate of the resampled signal to > 110KHz or about 14KHz above 96KHz in which case any claims of avoiding problems in the transtition would make marginally more sense.
Interesting. I found no reference in Benchmarks materials to any sample rate above 96KHz, must have overlooked it or it is another change in production compared to what the promo material claims.
Sayonara
Old 11th April 2005, 02:50 PM   #26
Default Re: Re: Re: Re: Eliminating jitter "completely" - Benchmark DAC1 approach
Originally posted by Kuei Yang Wang
Konnichiwa,
Sayonara
You mean you missed the description of the DAC1 as "a two-channel, 24-bit, 192-kHz Digital-to-Analog audio converter" as stated on the cut sheet, in the manual and on the website? Well, no one is perfect.
http://www.benchmarkmedia.com/digital/dac1/index.html
Old 11th April 2005, 04:05 PM   #27
Default Re: Re: Re: Re: Re: Eliminating jitter "completely" - Benchmark DAC1 approach
Konnichiwa,
No, I noted the DAC1 as "DAC1 - Two Channel 24-bit, 96-kHz D/A Converter " as stated on Benchmarks website:
and failed to observe any explicitly different statement which is only in the part of the blurp I never read at:
All I noticed where claims of using a 192KHz capable DAC Chip, which however does not imply acceptance of a 192KHz fs S/P-DIF or AES/EBU Datastream.
Sayonara
Old 11th April 2005, 05:38 PM   #28
00940 is offline 00940  Belgium
http://www6.head-fi.org/forums/showt...ight=benchmark
You can have the comments of a Benchmark engineer in there (starting post99). He notably justifies the use of the ne5534 against opa134 or the frequency picked.
Btw, the old models are 24bit/96khz, the new ones 24/192. The old ones can be upgraded.
Ben.
Old 24th April 2005, 07:52 PM   #29
atticus is offline atticus  United States
Just an FYI, but I worked in the marketing department at Benchmark when the DAC1 was released in 2002 and there was no intended misinformation given. The engineering staff was simply trying to make the most accurate dac they could in the price range and we (there were two of us at the time) just tried to tell people about it. Thanks.
My "audiophile" LM3886 approach mauropenasa Chip Amps 4512 Yesterday 05:44 PM
which FR driver and approach don't "gargle too much"? freddi Full Range 2 8th February 2009 10:14 AM
Copyright ©1999-2017 diyAudio
