Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Can a DEQ2496 be used as a simple "de-esser"?
Old 26th May 2006, 11:47 AM   #1
Cama is offline Cama  Netherlands
Default Can a DEQ2496 be used as a simple "de-esser"?
I use a Behringer DEQ 2496 in my hifi stereo set. It is really amazing what positive results you can get by using the GEQ and the PEQ. But now I wonder if I can use the Feedback Destroyer from the DEQ 2496 as a kind of “De-esser” to avoid the sharp esses that occur in many recordings of both male and female voices. I understand that the result will never be as good as when you use a dedicated De-esser or voice processor, but still. What adjustments should I make in the FBD? What frequency (s) must be killed?
Old 26th May 2006, 11:53 AM   #2
kexik is offline kexik  Slovakia
frequency depends on particular singer, mic and distance; freq. analyser and/or param. eq. (with high Q) sweep from 3 to 6 khz are necessary for every single case.
Old 26th May 2006, 12:49 PM   #3
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
I'd be looking at the tweeters before adding any extra processing.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 26th May 2006, 01:27 PM   #4
OK,
I have Magnepans MG12 planars. Initialy they sound bright and that is why I like them. But much recordings have esses that sound more than bright, shrill and not in balance with the rest of the sound. That is what I want to avoid or repair.
Old 26th May 2006, 02:12 PM   #5
R.I.P.
can be one or a combination of the following :
a) Too bright treble sounds reasonably good (fast) until you come
across spoken or sung siibilants, adding a series resistor to MG
treble units is quite common as far as I'm aware.
b) Poorly recorded CD's or LP's (if LP's also too bright a cartridge).
c) Amplifier clipping at peak levels.
/sreten.
Old 26th May 2006, 06:58 PM   #6
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
I have some 'sss' i would like to get rid of !
Could you explain ? I have a 3way speaker's setup
DCG3 Dual DCSTB, R2R DAC in build (2 ReflectorD's (+5VDC/+3.3VDC) + SSLV1.1 (+/-12VDC))
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
Old 27th May 2006, 03:19 PM   #7
R.I.P.
As far as I know 3-way Maggies are usually supplied with a
resistor that optionally can be placed in the treble circuit
to offer an alternative treble balance.
So I'd assume there is a jumper that can be removed, (the
treble unit is disconnected) and be replaced with a resistor.
/sreten.
Can a DEQ2496 be used as a simple &quot;de-esser&quot;?Hide this!Advertise here!
Mr White's "Opus", designing a simple balanced DAC Russ White Twisted Pear 1980 16th June 2018 02:42 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
