| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#21 |
Hi Terry
1 bit more noise, 5 bit less noise, R2R no noise Good 1 bit beats most R2R in linearity but all 1 bit DACs I had heard sounded tired and lifeless. I think R2R is better and also I start to believe non os is better but not TDAxxxx ... |
#22 | |
It decease signal level but the noise floor remains. |
#23 | |
Depends on internal topology, if you make R28 larger, the noise gain may well be reduced as a larger R has less noise current than smaller R. So they DR reduction may be less than anticipated. I spoke with AD applications engineers WRT this and they said there was "some" reduction in DR. However, it may well be well below the 16bit floor. I have an 1853 dac on the bench so I will give it a go when time permits. You are lucky to have APII, I am jealous. Cheers Terry |
#24 | |
My take here: analog noise is less objectionable than quantization noise which is still nicer than nonlinearities. Of course, with noise shaping, you get lots of out of band noise which combined with nonlinearities of the op amp input stages, will give you in band harmonics. |
#25 | |
Looking at the plots, the harmonics are virtually the same for both measurements, first and second being at -118 dB for 16 bits and maybe a tad worse for 24 bits at -116/117 dB (why?). The noise for for the 16 bit measurement is at -122 dB, i.e. equivalent to 20 bits of resolution. I suspect whatever device or software generated the 16 bit input data already used dithering, because no amount of dithering in the AD1853 could bring down quantization noise of a signal that was truncated or rounded to 16 bits. The noise floor for the 24 bit measurement is at -130 dB for the left channel and -135 dB for the right channel, equivalent to 21 - 22 bits of resolution (hence, I would feel comfortable with a limited amount of digital volume control that shifts 16 bit input data down within the 24 bit word). OK, big question then is why the THD+N of the 16 bit, apparently 20 bit dithered signal reads 94 dB. From eyballing the graph and trying to imagine an RMS addition of the first five harmonics and the -122 dB noise floor, I would still expect to come out with at least 100 dB. Is there a chance that the input bandwidth on the analyser was set to much more than 20 kHz? |
#26 | |
Something else is much more important: When you look at both 0dB graphs, you see that the harmonic spectrum is absolutely the same for 16bit and 24 bit, just the noise is reduced for 24bit. For this DAC which is a modern high end chip, higher input data resolution does only reduce noise, but not distortion. Why ? IMHO the linearity of the DAC is limited to 16 bloody bits or less. It is total nonsense to use high bit DACs if the only thing that happens is that noise is reduced and the distortion becomes more noticeable. Sound gets worse with more bits. |
#27 |
Berhard, those harmonics are in the -110 to 118 dB range. The quantization noise of 18 bits is also -110 dB. Those nonlinearities are hence better than 16 bits!
I suspect what we are seeing here are nonlinearities of the internal current sources or the external op amps at signal levels near full scale. Take a close look at the lower right hand corner of Fig. 16 of the AD1853 data sheet. THD+N has an optimum at about - 4 to -6 dB full scale, and as you move to full scale, THD+N degrades, which must be due to increasing nonlinearities. This is actually a sensible optimization, as you will see the MSB used only in rare transients where you don't much care for nonlinearities. However, if it makes you sleep better, attenuate all incoming signals by 1 bit (6 dB), and you will get 5 to 10 dB lower harmonic distortion. The degradation of S/N is insignificant with a DAC this quiet. Alternatively, you could use the AD1955 that seems to have solved this MSB distortion issue (fig. 12 of data sheet). |
| AD1853 dac's | sunrise | Digital Source | 7 | 21st June 2010 09:57 PM |
| Need help about AD1853 DAC. | shyliang | Digital Source | 7 | 13th July 2007 08:46 AM |
| It's my AD1853 DAC | Kochkurov Maxim | Digital Source | 8 | 13th July 2006 03:03 PM |
| My new AD1853 dac | AD1865 | Digital Source | 2 | 18th May 2005 12:15 AM |
| Another AD1853 issue | tiroth | Digital Source | 4 | 29th August 2003 01:12 AM |
| Page generated in 0.10391 seconds (80.36% PHP - 19.64% MySQL) with 11 queries |
