DIR 1701 and DIR1703 question - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 26th November 2002, 07:19 AM   #1
nFORCE is offline nFORCE  Japan
Send a message via ICQ to nFORCE
Default DIR 1701 and DIR1703 question
Dear all DIY player,
In DIR1701, it can use 12M or 16M can suit all kind of sampling rate input, (max = 96KHz), is it possible use one crystal in DIR1703 same as DIR1701 function?
nFORCE
Old 26th November 2002, 08:25 AM   #2
mpopovics's Avatar
Please check the datasheet.
For me does not seems, that it is possible.
There is a comparison table for different sampling rates with crystal frequencies.
But, I would like to know also more about it.
Old 26th November 2002, 09:20 AM   #3
hill's Avatar
nFORCE,
I don't think DIR1703 can work with a 12/16MHz external crystal.
In demo board, a 12.288MHz crystal has been included.
I don't know why TI prefer to use a ferquency which can not be divide exactly by 100MHz. But I'm sure that a low jitter clock source herein(supply a low jitter clock reference for dir1703) can make performance better.
I change therefore I am.
Old 26th November 2002, 10:57 AM   #4
Thanks alot Mr.Hill,
Still one more question.
If I use DIR1701 with 12MHz XTAL, that means can look like CS8412 can capable all sampling source? 32,44.1,48 and 96? with autodetect?
nFORCE
Old 26th November 2002, 11:40 AM   #5
Dir1703 make clocks from oscilator ( lrck, bitclock) if spdif is not connected in case you made automatic clock source selection like sugested by ti (pin27 connected to 28).
So i guess you can use 16 Mhz oscilator but you will have different clock fequencies when spdif is running or not.
My dir 1703 does not lock to input spdif stream but outputs mclk, lrck and bitclock, but i did not check this with 16Mhz crystal.
Good luck,
Aleksander
Old 26th November 2002, 01:55 PM   #6
mpopovics's Avatar
DIR1701 uses only 12/16MHz crystal
DIR1703 uses different crystal frequencies, specified on the datasheet.
borisov57!
Do not use DIR1703 with 16MHz crystal, it will not work.
nFORCE!
A 12 MHz crystal resonator can be used for 128fS (CSBIT), 256fS
(OPEN) and 384fS (BFRAME). And a 16 MHz crystal resonator is used for 512fS (BFRAME). The system clock
frequency can be set by control data at SCF0, SCF1 pin.
By using the SpAct frequency estimator (not the S/PDIF channel status bit), the DIR1701 detects automatically
the sample rate of an incoming S/PDIF signal and indicates the frequency at the BRATE pins.
Old 26th November 2002, 06:28 PM   #7
skaara is offline skaara  Slovenia
16mhz crystal wont work on dir1703, i tried that..
Old 3rd December 2002, 11:41 AM   #8
You are saying, that if you use 12.288 crytal (256*48kHz), you won't be able to lock to stand alone cd player spdif ( multiplier of 44.1 kHz).
I am very confused.
Question about DIR1703 SandroN Digital Source 27 1st June 2007 09:52 PM
DIR1703 question kostix Digital Source 1 5th July 2005 03:17 AM
DIR1703 spdif question jwagnerhki Digital Source 9 6th May 2004 09:14 AM
of dir1703, 1701 and cs8414? takashi Digital Source 0 14th December 2002 04:37 PM
Copyright 1999-2017 diyAudio
