Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Mood-Lab NON-OS dac
Mood-Lab NON-OS dac
Old 23rd May 2006, 02:43 PM   #1
reMC is offline reMC  Netherlands
reMC's Avatar
Default Mood-Lab NON-OS dac
Any experience with the Mood-Lab (under construction) dac? I'm considering buying it. Price is $199 for the basic version "concept" with 1 digital input and $399 for "dice", which has more digital inputs includes Toslink optical, coaxial and USB input for computer.
I really like the minimal concept (no input buffer, no reclocking) while the lay-out allows it to experiment with components.
Old 23rd May 2006, 03:39 PM   #2
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
looks a little overpriced to me.
If you can see the speaker cone move...it's not hifi.
Old 23rd May 2006, 04:12 PM   #3
reMC's Avatar
Care to tell why? I think it's the cheapest commercial available NON-OS dac, isn't it? Furthermore, I have no idea how it sounds! Do you?
Old 23rd May 2006, 04:32 PM   #4
Sure. I look at it from the point of view of a diy'er. I don't see fancy casework. And looking at the parts I arrive at a price of say 40-90 euro's.
I have an idea how it sounds but not exactly ofcourse, since I have not heard that particular one. I have heard 3 types of TDA 1543 nos with CS8412 receivers and I liked them all.
2 of them use 8*1543's paralled and the other was with a single TDA1543.
But for a commercial product it is not that expensive ofcourse. There is the pcb design costs. Dealer markup...etc. etc.
Old 23rd May 2006, 04:39 PM   #5
reMC's Avatar
Which one with a single TDA1534 did you hear? How did you like it compared to the 8 stacked dac's?
Old 23rd May 2006, 04:41 PM   #6
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
Just a bit.
Well, the layout is not optimal -- the PS is poorly done, the IV section should be closer to the tda1543, I have doubts about a carbon resistor for the PLL, the DAC chip is not decoupled well, if at all, the spdif input scheme is not so good, and socketing those chips is not a great idea here -- it makes sense in prototyping, but there is no reason to remove them. Also, the output impedence will be very high, so you will need to run it into an amp with an input impedence of at least 25K, if not 50K.
This doesn't mean it will sound horrible, but the tda1543 is very sensitive to the quality of the PS, and you can find better commercial versions with essentially the same schematic that will sound better. Moreover, you could build this better on stripboard for about $40-50.
-d
Old 23rd May 2006, 04:54 PM   #7
reMC's Avatar
Thanks for the feedback!
What's missing there?
Again, what's wrong? Are you suggesting a input buffer? It's just that i'm glad this design doesn't have it
And you can find better commercial versions with essentially the same schematic that will sound better. -d
I'm interested! Examples?
Old 23rd May 2006, 05:39 PM   #8
dsavitsk's Avatar
The 1543 likes a high quality small value film cap right on the power pin, and an electrolytic in the 220uF-470uF range nearby.
Or an input transformer -- it does a world of good.
http://www.gr-research.com/components/lite_dacs.htm
This is cheaper and corrects some of the issues. There are still some good modifications that can be done to this for cheap and it is missing the input stuff, but it is really cheap.
Old 24th May 2006, 04:35 PM   #9
reMC's Avatar
Thanks for the feedback, but I'm really searching for versions with 1 TDA1543, passive I/V and no reclocking!
Anyone?
Old 24th May 2006, 07:26 PM   #10
dsavitsk's Avatar
Well, you can buy Scott Nixon's kit and get the $50 worth of parts for $100. http://www.scott-nixon.com/dac.htm
Mood-Lab NON-OS dacHide this!Advertise here!
Tune the sound to the recording, or your mood . . . rick57 Solid State 16 25th February 2003 06:28 AM
Shakespeare in Bad Mood Jay Everything Else 10 20th February 2003 08:26 AM
