Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd May 2006, 09:23 AM   #1
jpfastre's Avatar
Default PLL doesn't lock in Tentlabs DAC
The PLL doesn't lock in the Tentlabs DAC (Tube DAC). I changed already U11, U12, U13, U14, U15, U17 without result. I checked the resistors and capacitors of the PLL circuit. The bicolor LED lights red at the start and lights than alternate green or red.
The output voltage at pin 6 of the TLC251 is a unstable voltage around about 2.5 V. I use the Tentlabs VCXO.
Please help.
Old 23rd May 2006, 09:34 AM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Have you asked Guido Tent? I bet he will be happy to help you out.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 23rd May 2006, 12:45 PM   #3
jpfastre,
Before changing parts did You try the Dac with different sources?
This Dac is really sensitive for the right [absolute] frequency value of the CD drive unit's clock source. It's not enough to suppose that Your drive is good / expensive so it's OK. For example I have a Rotel RCD 990 which was totally off, I had to adjust it. On the other hand some CD roms were just right [with their ceramic resonator..]
I would say it's a defect of the PLL if You were not able to find not even one drive unit with which it would work.
Ciao, George
Ps.: By the way it's a TLC271 which was originally designed in..
Not a big difference, but maybe some offset problems could come up without adjustment?
Old 23rd May 2006, 10:42 PM   #4
jpfastre's Avatar
I'll try it .
I tried it with two CD players and one DCC recorder with the same result.
My mistake, it was a TLC271
Any suggestions?
Old 24th May 2006, 03:02 PM   #5
Next idea: are You sure that the Cs8412 itself gets locked right in the first place?
Because from Your description it seems that the dc levels / circuit behaviour is OK for a free running system.. So, does things change when You plug/unplug the input SPDIF signal?
Though it will be hard to do smthing without at least a scope..
Ciao, George
Old 24th May 2006, 08:56 PM   #6
jpfastre's Avatar
Hallo George
When I remove signal:
The LED lights yellow= signals no SPDIF
pin 25 of CS8412 goes high = ERF
pin 6 of TLC271 goes to zero Volts
I have a simple old one channel scope.
What can I do?
JP:
Old 25th May 2006, 09:14 AM   #7
Jp,
So it seems to work, the 8412. And also the phase comparator section works in some way. Hm.
With the scope You should observe signals similar to these:
http://www.diyaudio.com/forums/showt...521#post175521
see also here:
http://www.diyaudio.com/forums/showt...296#post185296
If You checked:
all power supplies, with the scope, and it's 5V DC with absolutely no signs of oscillation, also it's 6V Dc on the TLC271, and no osc. also there, [Always suspect those LM317's.. aproposito, what kind of cap did you apply on the reg's output? 10uF solid polimer - might be a problem]
And there they are both the ~ 700 KHz 5v square wave signals on the output of the two counters/dividers;
and there it is the sawtooth signal as described in above link on the "pll sound" output;
Then still there is the possibility that your external sources are so unfortunate [or the VCXO is not up to tolerance..] that You can not get into pull-in range; this problem can be checked by a high precision freq. counter; [if you can organize one]
Also there might be a problem with the filters time constants, so your PLL loop is not stable. This should not be a problem if all the main filter caps are film as prescribed; all the resistors are really that value that prescribed.
My guess would be these last two possibilities + or a possible PS problem, as from your description the main functionality seems to be there..
Old 26th May 2006, 08:12 AM   #8
jpfastre's Avatar
Hi Georges,
Thank you for your help, I feel we are close to diagnostic it.
Voltages OK and no trace of oscillations.
Vishay solid aluminium.
pin 3 U13A and pin 3 U14A (picture) near identical.
pin 5 and 6 of the same IC's: block cyclic changing in width. Is that normal?
pin 3 U15: picture
Pll sound output gives the sawthoot but mixed with another wave.
I'll check it again.
JP
Old 26th May 2006, 11:47 AM   #9
jpfastre's Avatar
pin 3 U15: picture
Old 26th May 2006, 11:47 AM   #10
jpfastre's Avatar
PLL sound output
Signal Lock LED w/ CS8414? fluckscapacitor Digital Source 4 31st July 2005 07:23 PM
Cs8414 Lock LED leo529 Digital Source 1 24th November 2002 01:14 PM
Page generated in 0.10284 seconds (82.29% PHP - 17.71% MySQL) with 11 queries
