Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd May 2006, 03:57 AM   #1
Default Prototyping with SMD
I'd like to begin prototyping a DAC, which will obviously have many SMD components. I think all the IC's and op amps can be put on DIP adapters, so those should be easy. The component I'm wondering about is the XO. For the actual PCB, I will most likely use a SMD chip. Is it o.k. to prototype using a pin- and voltage-compatible DIP chip, and then design the PCB using SMD components? I've been told the high frequency of the crystal (24.576 MHz) can be a problem during prototyping. I suppose many of you have a lot of experience with the general problem of prototyping SMD components. Can I get some recommendations? Also, while we're at it, are there any preferences for breadboards, protoboards, etc.? Thanks, in advance.
Old 23rd May 2006, 06:28 AM   #2
hagtech's Avatar
I would not recommend using adapter sockets, as the increase trace lengths can lead to stability problems. No way to get decoupling caps nice and close.
Probably worth the time to invest in a circuit board.
jh
Old 23rd May 2006, 06:42 AM   #3
poobah is offline poobah  United States
poobah's Avatar
Goto DigiKey dot com and enter "surf board". That will give you some ideas. The socket adapters are OK... but could give you some problems as pointed out above.
In general. you can use through hole equivalents for prototyping. There are exceptions though and you'll only find them the hard way. Speed (frequency) would probably be the biggest factor... more speed... more problems.
Vector boards, described as "3 pads per hole with power & ground" work well for me... and I've dome some real fast one-off circuits with those. I think your 25 mHz, with through-holes would be fine... just keep things tight and tidy.
Old 23rd May 2006, 06:53 AM   #4
Ha! Bunch of quiche eaters. This is how real engineers do it.
For the young, those blue things under the 'scope are called databooks.
Old 23rd May 2006, 06:56 AM   #5
poobah's Avatar
Hmmmm,
I guess you worked at Amdahl then?
Old 23rd May 2006, 07:57 AM   #6
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Default Re: Prototyping with SMD
Originally posted by ezkcdude
........... Can I get some recommendations? Also, while we're at it, are there any preferences for breadboards, protoboards, etc.? Thanks, in advance.
Look here...you may find something to suit.
I've used board #1560
www.onepasinc.com
Andy
Old 23rd May 2006, 12:39 PM   #7
Thanks, everyone, for being so responsive! I just won an auction on eBay for my first scope yesterday (Tek 465B), so I should have plenty to keep me busy. Full steam ahead...
PCB prototyping services- Cheap pcb4all Vendor's Bazaar 15 1st February 2009 02:18 AM
Prototyping board - Can anyone identify ? Atilla Parts 2 25th August 2008 06:36 PM
Prototyping Board gssmind Swap Meet 3 11th September 2006 02:27 AM
Instant Crossover Prototyping bzdang Multi-Way 44 2nd July 2005 04:48 PM
Prototyping a 100W CFB amp... OliverD Solid State 15 7th March 2004 09:53 PM
Page generated in 0.74979 seconds (10.81% PHP - 89.19% MySQL) with 10 queries
