Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th May 2006, 08:12 PM   #1
percy is offline percy  United States
Default Quantization Levels and Dynamic Range
I understand that 16 bits can represent 65536 unique amplitude levels. Now dynamic range is defined as the difference between the maxiumum and minimum levels that can be represented.
Lets say that the minimum level is 0 and maxium level is 65536, so the dynamic range is 96.3db, or so I have read/heard in most places.
However, although 16-bit does mean 65536 unique quantization levels, it is actually +32767 to -32767, so the maximum swing on each side of 0 is really only 32767. So why is the dynamic range based on 65536 levels of quantization and not 32767 ?
Shouldn't the dynamic range of the 16-bit audio cd then be only 90.3db ? (that too only theoritically, would be still lower practically). Its like asking - is the dynamic range based on the peak signal level or the peak-peak signal level ?
Am I thinking this through correctly ? or am I missing something big here ?
Old 19th May 2006, 09:04 PM   #2
Bernhard's Avatar
Music is AC signal so peak-peak.
Old 20th May 2006, 04:25 AM   #3
but in any other AC signal db gain/difference calculations - for example voltage gain - the voltage that is being referred is not p-p.
Old 20th May 2006, 07:30 PM   #4
ghetto is offline ghetto  United States
I'm not really sure how to explain it other than, the signal is still being described by 16 bits, so it doesnt matter if part of the signal goes below "0 volts" ... its still 96dB.
Old 20th May 2006, 07:33 PM   #5
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Default Re: Quantization Levels and Dynamic Range
Originally posted by percy
However, although 16-bit does mean 65536 unique quantization levels, it is actually +32767 to -32767, so the maximum swing on each side of 0 is really only 32767. So why is the dynamic range based on 65536 levels of quantization and not 32767 ?...................
Hi
It is not an AC signal !
The levels go from 0 - 65536
They are just offset in some DACs
Andy
Old 20th May 2006, 07:38 PM   #6
SY's Avatar
Not exactly. Gain RMS is the same as gain peak is the same as gain peak to peak. For example, let's say I have a box with a gain of 10. Then 1V RMS in gives 10V RMS out. 1 V p-p in gives 10V p-p out. And so on and so on.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 20th May 2006, 07:54 PM   #7
phn is offline phn  Sweden
phn's Avatar
Scuse me, but is peak to peak applicable here? We're talking "ones" and "zeros"--2^16--here, aren't we?
Old 20th May 2006, 08:42 PM   #8
SY's Avatar
Yes it is. We're talking about signal peaks. The question really is, is RMS applicable here?
Old 20th May 2006, 09:08 PM   #9
moamps is offline moamps  Croatia
....although 16-bit does mean 65536 unique quantization levels, it is actually +32767 to -32767, so the maximum swing on each side of 0 is really only 32767....
Hi:
The minimum swing isn't 1bit on each side (two bits). It's just 1 toggling bit (half bit on each side ). The toggling bit may represent a converted sine signal with 1bit peak-peak value, for instance.
So, if the signal's minimum value is 1bit peak-peak and the maximum value is 65536 peak-peak, the dynamic range is 6.02*n or 98dB for n=16. Theoretically, the dynamic range is even higher for 1.76dB (sine signal). In practice, 90dB is a more realistic value.
Milan
Old 20th May 2006, 09:25 PM   #10
phn's Avatar
It was in that line I was thinking. Maybe I'm stumbling on the semantics.
Dynamic Range...? Lyra Digital Source 40 2nd October 2007 11:44 PM
SNR/Dynamic range worsens in low frequency range. percy Digital Source 3 1st June 2006 12:41 PM
Page generated in 0.09289 seconds (83.77% PHP - 16.23% MySQL) with 10 queries
