diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   please advise.. ext. LPF summing differential outputs by an opamp (http://www.diyaudio.com/forums/digital-source/79727-please-advise-ext-lpf-summing-differential-outputs-opamp.html)
ASSaBeong 17th May 2006 11:15 AM
2 Attachment(s)
Hi
Please some advice...
pc soundcard -- AK4395 DAC board -- headphone amp -- headphone.
I want to modify analog low pass filter section connected to AK4395 DAC's output.
change opamp(2134 --> ad8620,opa627,lt1115,ad797,ad843...)
opa 2134 is operating as an analog low pass filter summing the 4395's differential outputs.
change power supply bypass caps
(general purpose 85' AL --> 105' low impedance AL cap)
(0.1uf mks --> 0.1uf mkp)
change the film cap, determining the cut frequency slope??
(2.2nF mks --> 2.2nF fkp, mkp or silver mica)
change output coupling cap??
( 47uF 85' general purpose AL, SMD type, --> ?? suggest!!! )
Please some advice.
Thank You.
analog part circuit is attached.:)
Resources saved on this page: MySQL 18.75%
