Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th May 2006, 01:57 PM   #1
Default Suggestions for balanced DAC output?
So, I'm desiging a DAC which will use PCM1794, and I want to have balanced output. I'm trying decide between using fully differential op amps (e.g. OPA1632 or AD8138) or separate op amps for + and - signals (possibly AD8065/6 or AD8610/20). Does anyone have specific suggestions/advice/experience doing this? It seems there are not too many balanced designs out there.
Old 16th May 2006, 03:35 PM   #2
hifimaker's Avatar
There's a discussion about this topic in the Pass forum:
Anyone built a Pass D1 I/V for a TI1794 or TI1794 DAC?
Old 16th May 2006, 04:24 PM   #3
-ecdesigns-'s Avatar
Default balanced outputs
Hi, ezkcdude,
I found this link:
http://sound.westhost.com/balance.htm
It contains several balanced designs using single OP-amps
Old 16th May 2006, 04:28 PM   #4
Thanks, I guess I have a lot of reading to do!
Old 16th May 2006, 04:37 PM   #5
ece, just read that link. I think maybe the balanced line receiver approach might be the best for me. It's a single-ended output, but probably has most of the benefits of a balanced design anyway (i.e. common mode rejection). Since I won't be driving very long cables, maybe it's not essential to have true balanced outputs. Also, it appears like a very simple design, and is already suggested in several data sheets that I've been looking at.
Old 16th May 2006, 04:44 PM   #6
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
I wonder if some one has a really good ciruit to turn a non balanced dac into a good performing dac with balanced. I guess i could use DRV134's but are they really that good ?
Old 16th May 2006, 05:12 PM   #7
I would imagine one way of doing this is to split the single-ended signal into two op amps, one inverting and the other non-inverting. I suspect that maintaining correct phase of the signal may be pretty hard.
Old 17th May 2006, 03:39 AM   #8
There's a very simple circuit diagram for balanced to single-ended conversion in AD's "Data Conversion Handbook" (Fig. 6.70 on p. 417). I think I may just try this design first, at least, in the prototyping stage. I've attached a schematic of the I/V stage with the PCM1794, if anyone's interested. I should note that I've drawn it using AD8620, which is a dual op amp. This is a convenient choice because you can get a Brown Dog pre-mounted DIP.
Old 17th May 2006, 07:51 AM   #9
00940 is offline 00940  Belgium
it's just a passive I/V conversion followed by a balanced to single ended converter.
Ben.
Old 17th May 2006, 11:27 AM   #10
Yep. I've changed my mind about keeping the output balanced. This method still has the advantage of common mode rejection, which I think is important. It's also about as simple as an op amp setup can be. Also, the AD862X has specs very similar, if not better, than OPA627.
Suggestions on Balanced Bridge circuit Mambo Solid State 5 12th January 2007 04:05 PM
ono balanced output pamaz Pass Labs 6 3rd March 2004 11:20 PM
Suggestions on Balanced Line Stage - parts? lgreen Pass Labs 3 4th May 2003 03:07 AM
Suggestions for a battery powered NON-balanced Mic Preamp? Phloodpants Analogue Source 4 23rd December 2002 05:22 PM
balanced output wuffwaff Solid State 14 16th January 2002 06:54 AM
Page generated in 0.13373 seconds (74.97% PHP - 25.03% MySQL) with 11 queries
