| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I am considering buying a minidisc deck (for convenient audio recording of material I have on phillips cassettes - I am not fond of cassettes mechanical abilities.
Out of interest how does the distortion introduced by the Atrac compression manifest itself compared to a CD?
heretics are sometimes right |
#2 | |
diyAudio Moderator Emeritus
#3 |
Thanks Bas ,
I was hoping that might be the answer .It wouldnt have stopped me buying one anyway because most of the source material I want to " rescue" is on phillips cassette and not of fantastic quality but is not replaceable .I just thought I might also make convenience backup copies of some of my favourite cd's and wondered if they would be very different . I,m 58 anyway so my golden ears days if I ever had any are over !
#4 |
When I had Mission 760 speakers I could not reliably tell the difference..(I don't know even if I could today....
Unfortunately my minidisc player gave up...so I can't do the comparison with the stuff I've got these days.
#5 | |
Not if you listen to Orbital or Kraftwerk. Minidisc can't cope with electronic music. It significantly alters the tonal balance to extent that some sounds disappear altogether. |
#6 |
The newer Hi Md format will record 16bit 44.1khz (full cd resolution). you can pick up a sony portable unit for ~$400.
#7 |
Nyatt,
I was considering the ordinary 80 minute md deck something like a sony cmt-md1 or the sharp md-mx10 are these decks very inferior to the later hi-md ?
#8 |
I have played with the normal minidiscs, but these new hi-md's are quite a bit better sounding (again, full cd resolution!). I haven't seen any home units, but I would imagine Sony makes a few. Makes for a nice tiny portable.
#9 |
Since I last posted I have acquired a sharp md-mx10 off EBAY for £60+ (I chose it because it fits my shelving under stairs) and i am very pleased with it so far. I am only using it as a deck ( ignoring the speakers and the built in power stages) to drive into the Leak 2000 receiver . It has phonos in for AUX, but for now I will have to use the h/phone out socket . Should I pad this with a resistor ? it seems to drive the Leak O.K. as is. Presumably low impedance into high impedance is O.K.?
| Converting CAL CL10 5 disc player to a single disc player | stoolpigeon | Digital Source | 0 | 27th May 2007 02:25 PM |
| A New Use For That Mp3 And Mini Disc Input | MrGuitardeath | Instruments and Amps | 0 | 2nd July 2004 05:21 PM |
| A New Use For That Mp3 And Mini Disc Input | MrGuitardeath | Car Audio | 1 | 2nd July 2004 04:55 PM |
| Disc Stabiliser | mrfeedback | Digital Source | 1 | 2nd October 2003 04:06 PM |
| Page generated in 0.10587 seconds (79.12% PHP - 20.88% MySQL) with 10 queries |
