Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th May 2006, 06:55 PM   #1
Zodiac is offline Zodiac  United States
Default 3.3v to 5v CMOS interfacing
Hi
I'm trying to interface a 3.3v logic output (from a PCM2706 USB receiver) to a 5v TTL input (HC4024 counter). Is there any easy way to do this for example using a transistor switch? Googling hasn't brought any easy answers... or would swapping the HC for a HCT do the trick?
Any help greatly appreciated
Old 14th May 2006, 08:03 PM   #2
Real_Macgyver's Avatar
Yes, you can use a single transistor as a level converter. Use a CE stage, 3.3V input on the base and output on the collector.
The collector needs a resistor on a few kohm and the emitter is grounded. The collector is connected to +5V and the output signal is taken after the collector resistor. This makes it swing between +5V and 0V. Notice that the signal will be inverted. Don't forget the base resistor.
Old 14th May 2006, 09:01 PM   #3
BlackCatSound's Avatar
You should be able to find the input switching thresholds for the TTL gate, but an HC is not TTL, its CMOS.
Its very likely the 3v3 output will drive it directly, no need for any 'glue'.
Old 14th May 2006, 09:27 PM   #4
Dave is offline Dave  New Zealand
HCT logic will work with 3.3v input signals.
Old 14th May 2006, 09:47 PM   #5
Thanks, I kinda thought that would do the trick....sounds straightforward enough! I guess 100r for the base and 2k for the collector would be ok?
Old 14th May 2006, 09:49 PM   #6
Yeah I made a mistake - it's CMOS not TTL therefore I was having voltage threshold problems, figured that bit out with a scope after tracing the circuit from the master clock output of the receiver
Thanks for the help
Old 15th May 2006, 09:43 PM   #7
no luck it seems... inserted an NPN transistor switch in the circuit, base connected via 470r resistor to the output of the receiver chip (high state 2.8v, low 0.4v), connected emitter to gnd and collector to 5v via 2k47 resistor. Output to circuit from collector / resistor junction.
Looked at it with a scope and multimeter - looks like the collector is saturated permanently (hanging at 15mv or so), scope shows signal on one side of the 470r resistor, not on the other
Any ideas? Why not working!¬!!
Old 15th May 2006, 09:47 PM   #8
darkfenriz's Avatar
Try open collector or open drain buffer.
Old 15th May 2006, 10:03 PM   #9
Whats an open drain buffer when its at home!?
Also what should I be looking for?
Old 15th May 2006, 10:11 PM   #10
Just swap to an HCT device, the transistor and pull resistor will be probably be too slow on the rising edge anyway.
new interesting CMOS op-amps Dominique Solid State 12 4th April 2011 06:42 PM
24 bit ADC interfacing with ARM using I2S sukhdeep Digital Line Level 2 20th June 2009 03:37 PM
Recommendation for a good CMOS op-amp? rruss Solid State 8 20th October 2004 08:39 PM
cmos inverter speed till Digital Source 6 21st June 2004 02:51 AM
which is a better spdif-to-cmos converter? rlim Digital Source 4 15th June 2004 07:03 AM
Page generated in 0.10834 seconds (81.65% PHP - 18.35% MySQL) with 10 queries
