diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   Jensen 4 pole (http://www.diyaudio.com/forums/digital-source/79454-jensen-4-pole.html)
wendell c 12th May 2006 03:40 PM
Jensen 4 pole
Hi everyone, I need help installing the Jensen cap on my Toshiba 3950
it came with a diagram, but I still don't know where to hook up the inputs on the diode bridge. Maybe someone here has a pic on where on the bridge I'm suppose to connect it to.
Hopefully, someone here can lead me in the right direction so I can stop blowing fuses:D
David Garretson 14th May 2006 12:07 AM
Are you saying you can't ID the input/ouput terminals on the cap, or that you can't ID the +/- outputs from the diode bridge?
wendell c 14th May 2006 06:20 AM
can't id from diode bridge, at first I couldn't id cap but someone had a pic and figured it out, at first it was backwards.
David Garretson 14th May 2006 11:55 AM
Please describe the diode bridge. Is is standard, or custom with multiple diodes on rails as sold by RAM?
wendell c 14th May 2006 03:25 PM
standard bridge? I will try to post a pic or something tonight. Thanks!
wendell c 16th May 2006 09:15 AM
I finally installed the cap correctly after trying different ways of connecting onto bridge, this came about afer blowing about 8 fuses and frying a Ps board.
Thanks for those who really tried to help:D
classd4sure 16th May 2006 09:57 AM
boy, good thing for fuses huh?? You really should make an effort to know how it's to be connected before trying it every which way, can be dangerous otherwise.
Resources saved on this page: MySQL 18.75%
