Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th May 2006, 11:07 PM   #1
Steerpike's Avatar
Question CDM1: help please: removal of spindle motor shaft
Re the CDM1 (mk1) mechanism.
Does the spindle motor shaft come out from the top, or the bottom? Must I remove the disk turntable (how???), or the motor rotor to get it to come apart?
Old 13th May 2006, 02:25 PM   #2
Lourens is offline Lourens  Europe
Hi Steerpike,
Turntable and shaft are inseparable. They come out from the top. See attached exploded view from the service manual.
Lourens
Old 13th May 2006, 04:58 PM   #3
tubee is offline tubee  Netherlands
tubee's Avatar
Whats the problem with the CDM-1 Steerpike?
Daisy Bell
Old 13th May 2006, 10:26 PM   #4
Steerpike's Avatar
Thanks Lourens! That diagram is exactly what i needed!
It's in a ReVox B226.
The spindle is a little "stiff" or feels heavily damped. No audio problems yet, but the disc stops immediately the power is shut off - there is no inertial run-on. I imagine there should be some free-wheeling of the spindle and disc, although the motor does not yet seem to be struggling to overcome the load. What prompted me to investigate this is that the transport has become a little noisier than I remember it being.
Old 14th May 2006, 07:15 AM   #5
tubee's Avatar
I had the same with my CD304MK2 CDM1, sometimes the toc won't read. I removed the underside motor parts only. The spindle rests on a teflon plate, it was lightly oxidated(brown), cleaned it(beware of scratches on axle, did that with a fingernail), new clock oil on bushes/spindel and some grease on teflon plate and its allright now.
You have to align the bearing until it turns freely when reassembled with locking of screws.
Good luck
Daisy Bell
Old 14th May 2006, 01:02 PM   #6
Lourens, you wouldn't happen to have a service manual for the CDM1.2 by any chance?
Old 14th May 2006, 09:04 PM   #7
AFAIK there is no dedicated sm for Philips CDM1 mkII (the one you're looking for?). I found this exploded view of it in the Philips CDD882 manual.
For complete servicing information of the CDM1 mkII you need to have the Philips CD880 manual as well.... Both, and many others on one cd, obtainable from http://ultranalog.com/
Old 14th May 2006, 09:32 PM   #8
Thanks!
Old 15th May 2006, 08:24 AM   #9
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Originally posted by tonyptony
Thanks!
Hi.
A complete set of the servicing manuals for CDM0 - CDM9 is available from CAS, Germany
service[at]cas-germany[dot]com
about 10e
Andy
Old 15th May 2006, 05:51 PM   #10
tubee's Avatar
The cdm1mk2 looks allmost the same as CDM2 as i see how it is constructed now.
Daisy Bell
TT motor spindle source BobM Analogue Source 2 8th May 2009 02:36 PM
Source for CDM 4 Spindle Motor auric Digital Source 1 13th November 2008 03:48 PM
Bent motor Shaft TD160 enzedone Analogue Source 16 14th October 2007 08:40 AM
Tweaking: Bypassing spindle motor with caps: Yay or Nay? Scorpio(DDMF)! Digital Source 5 25th March 2007 12:58 PM
Need spindle motor for Panasonic DVD player Original Burnedfingers Solid State 10 25th June 2006 06:51 AM
Page generated in 0.10733 seconds (80.91% PHP - 19.09% MySQL) with 11 queries
