Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th May 2006, 09:28 AM   #1
Angry Pioneer PD-75 Cd Player whistling
I bought this reference series player in Manchester from new many years ago. It has the Pioneer stable platter mechanism and is in mint condition. It is a wonderful device and looks gorgeous. Even better it sounds gorgeous, that is it did.
From cold it will play a CD for a few minutes. When I eject the CD and insert another. no music, just a whistling sound from the player. The fault symptom persists until I switch off and leave for a few minutes. Then the cycle repeats. I should add that when whistling the palyer is slow to repond to ejecting the CD
Does anyone have any ideas what the problem is as really would like to repair it or have it repaired. iam a novice in this area but with knowledge consider myself reasonably technical competent.
Kind regards, Allan.
Old 7th May 2006, 09:38 AM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
I'd have a look at the power supply caps to begin with.
I don't know this particular player but some pioneer models suffered from bad spindle motors.
/Hugo
Old 7th May 2006, 11:43 AM   #3
Ruach is offline Ruach  Singapore
The whistling sound is probably caused by the platter spinning out of control at high speeds. This also explains why it takes a longer time to eject the platter.
When this happens, one reason could be that the servo circuitry is down or that it is not receiving a proper clock signal.
Do a inspection of the 5V power supplies to the dac chip. I believe that the clock draws its supply from the same rails.
As a last resort, you can always send it back to Pioneer for servicing. Hope this helps.
Old 7th May 2006, 12:00 PM   #4
Audiofanatic's Avatar
Default LASER Unit
Hi Guys,
I have two Pioneers in my lab and both had the same problem.
In both cases the laser unit wasn't good (read: dead).
I've replased both and (this is the pain in the b*t part) adjusted the player to factory specs. After that, both played like new and sound better than ever.
I hope this helps.
Best,
Audiofanatic
Be nice to animals.
Old 7th May 2006, 12:10 PM   #5
That could be another reason too though I have yet to encounter it.
Replacing the laser yourself would be very painful
Old 7th May 2006, 12:22 PM   #6
Netlist's Avatar
Agreed, I tried a few time myself but ended up sending it to Pioneer.
/Hugo
Anyone have a Pioneer DV-S9 or PD-S06 player to SELL? stephensank Digital Source 1 21st October 2008 11:07 PM
Best Pioneer player for modding wmj Digital Source 0 19th January 2007 03:04 AM
Pioneer cd player pots PIY Digital Source 15 26th January 2006 12:15 AM
Whistling Sound after modding Philips Player diyman Digital Source 4 18th November 2005 01:46 PM
Pioneer CD Player Problem Noak Digital Source 2 4th September 2005 04:30 AM
Page generated in 0.08077 seconds (74.01% PHP - 25.99% MySQL) with 10 queries
