Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
CD63 display problem
Old 2nd May 2006, 11:31 AM   #1
Chivvyp is offline Chivvyp  United Kingdom
Default CD63 display problem
I made some mods to the power section of my CD63KIS at the weekend.
As I'm an idiot I put +12v and -12v voltage regs in with wrong orientation.
I corrected this but now I have no display and the control panel buttons (and rc) don't work. I am getting audio output though.
I've traced the power lines and seem to be getting power through the ribbon cable to the display.
Anyone got any ideas where to look next? Is it possible I've fried a component somewhere?
Old 2nd May 2006, 12:04 PM   #2
martin clark is offline martin clark  Europe
If it turns out you have fried it - I've got a complete and working front panel from a CD63 you can have for the cost of postage. Drop me an email if interested.
Old 2nd May 2006, 02:16 PM   #3
poynton is offline poynton  United Kingdom
poynton's Avatar
Default Re: CD63 display problem
Since you have audio, you do not have a problem with the +-12v supply. [ The +-12v supply is audio only ]
First place to start is the VFTD supply at Q851, [close to the transformer] the voltage on its pins, to ground, should be-31.5v, -24.4v, and -6.8v.
Next, check the voltage either side of resistor, RF01. This is next to the big chip by the display. Voltage to ground should be +5v both ends.
Andy
Old 3rd May 2006, 09:07 AM   #4
Andy,
I checked Q851, viewing from front, l > r I got -6.9, -34.4, -24.6.
RF01 I got +5 going in but 0 coming out. Guess this may be the problem. I'll replace it at the weekend and see what happens. Or are there other things I should check first?
Not sure how this would have been affected by the changes that I made but maybe it was just coincidence?
Thanks for your advice.
Pete
Old 3rd May 2006, 09:43 AM   #5
poynton's Avatar
Andy,
Pete
The readings round the regulator are OK.
RF01 is the 'safety' resistor feeding the +5v to QF01, the uP.
This should not have been damaged by the 12v supply problem !!
Check for solder splash or other foreign bodies from your previous soldering.
Andy
Old 3rd May 2006, 11:03 AM   #6
Thanks Andy, will do.
Any idea where I can get a suitable resistor for RF01. I checked on Maplins site but the only 4.7 resistor I could find was rated 0.6w rather than 0.25.
Pete
Old 3rd May 2006, 11:15 AM   #7
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Hi Pete, you could just replace it with a piece of wire for now. Or use a similar small resistor, whatever wattage you like: it just won't fit in flat.
Simon
Old 3rd May 2006, 11:18 AM   #8
SimontY's Avatar
I also broke my display, hehe. And I did before one time, which was caused by lifting a solder pad under the big cap near the 7805 (+5v regulator).
This time the problem is elsewhere, but sadly it's a different problem to yours, so we can't help each other much
Simon
Old 3rd May 2006, 04:46 PM   #9
Simon,
thanks for the advice, I think I'd better use something "blowable" to start with in case I havent solved the root problem completely.
Pete
Old 3rd May 2006, 07:18 PM   #10
poynton's Avatar
Pete
Hi.
Half watt will do. Definately not a short in case there are problems as you said.
RD01 and RD04 near the opamps are also 4.7ohm. [ you could short here as no problems.]
Andy
CD63 display problemHide this!Advertise here!
Problem with Marantz CD63 - Need help Ruach Digital Source 10 22nd April 2013 04:07 AM
Marantz cd63 ki no display paul_peraic Digital Source 2 25th May 2008 06:22 PM
marantz cd63 digital out problem dublin78 Digital Source 1 7th December 2007 02:34 PM
CD63 Problem. Need Help! binatang Digital Source 13 13th April 2006 08:03 AM
CD63 display died, please help SimontY Digital Source 39 4th March 2005 12:21 PM
Copyright ©1999-2017 diyAudio
