Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd May 2006, 01:36 AM   #1
percy is offline percy  United States
Default low pass "PI" reconstruction filter ?
Has anyone used a pi filter as the final low pass reconstruction filter after the dac ? Is it feasible to do so ?
I am also looking for information on the phase response of such a filter. Where can I find design, operation and application information of such a filter for this purpose ?
Thanks!
Old 2nd May 2006, 07:18 PM   #2
Bricolo is offline Bricolo  France
Bricolo's Avatar
a pi filter is just a 3rd (sometimes 2nd when a resistor is used instead of a coil) order filter
the name pi comes from the shape of the character pi, that matches the schematic of "C1 to ground, L1 between C1 and C2, and C2 to ground"
so it's a classical filter, it has no specific phase or amplitude response, it depends of the components values and the "alignment" (butterworth, bessel, something else...)
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 2nd May 2006, 11:29 PM   #3
By phase response I meant the phase shift, or distortion, or linearity, or whatever of the filter - the same effect because of which very higher order or steep analog filters are not desirable for this application or purpose.
I found this thread - Low pass filter design for TDA1541
as shown in post# 18 and 19 the simulated response is indeed very steep so I wanted to find out what the phase linearity of a real pi filter looked like.
Old 3rd May 2006, 03:14 PM   #4
macboy is offline macboy  Canada
...as shown in post# 18 and 19 the simulated response is indeed very steep ...
No, it isn't. Check out the vertical scale on the graph... a total of 5 dB are being displayed. So even though it appears steep, that is just a visual artifact of the very small vertical scale. The graph probably is zoomed in like that to show the small amount of pass-band ripple, which would be impossible to see with a 100 dB scale. Likewise it is impossible to see stop-band response with a 5 dB scale. It is a 3rd-order filter so it will have a 3rd-order slope: 18 dB/octave. You can count on that. How it behaves (in amplitude and phase) around the crossover frequency will be determined by the alignment of the different reactive components, as mentioned earlier.
Old 4th May 2006, 01:13 PM   #5
ok. thanks for pointing that out.
in general then does a pi filter offer any advantages over any 3rd order filter ?
Old 6th May 2006, 08:45 AM   #6
Bricolo's Avatar
it is a 3rd order filter
schematic variation and sim results of Pass "X" series US pat 5376899 tiefbassuebertr Pass Labs 13 30th July 2009 09:33 PM
Hi Res 550mm Fresnel Lens Set, 15"x11" First Surface Mirror, 6.3" IR/UV Filter, More! Ben_Tech Swap Meet 0 22nd September 2007 11:49 PM
power supply schematic with a 6080 used as a "pass tube" jarthel Tubes / Valves 1 27th May 2006 04:41 PM
Reconstruction filter from "Opamp applications" (Jung) 00940 Digital Source 7 10th November 2005 10:19 AM
Page generated in 0.08061 seconds (75.88% PHP - 24.12% MySQL) with 10 queries
