Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st May 2006, 04:55 PM   #1
farl is offline farl  United Arab Emirates
Default clock upgrade Marantz cd7300
Is there a benefit if i well upgrade the clock for this CDP? Cause it is connected to the PPL & VCO before it is distributed to the digital cicuit.
Or is it possible to connect the clock directly to the CD decoder and terminate the PPL & VCO.
PPL & VCO is controlling the pitch of the CDP.
Help please..........
Thanks,
Farl
Old 2nd May 2006, 06:29 AM   #2
here is the block diagram:
Old 2nd May 2006, 08:45 AM   #3
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
Hi Farl,
The clock distribution in the CD7300 is quite complex. Just changing the clock will not bring you much benefit, it has been discussed elsewhere. If you do a search on this (and other) forum, you will find some more info.
Ray.
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 2nd May 2006, 10:00 AM   #4
Thanks Rey.
What about if I will cancell the clock input of the DAC and change it to a low jitter clock with the same freq. Is it possible?
Farl
Old 2nd May 2006, 12:51 PM   #5
6h5c's Avatar
Originally posted by farl
Thanks Rey.
Farl
Hi Farl,
No, that won't work. The decoder and DAC need the same clock, it needs to be synchronious. Same goes for the MP3 and CD-text decoder chips that are aso attached to the clock signal. The thing that might have a positive effect is to get rid of the VCO and PLL and insert a stable clock there, with a separate PSU. You will lose the pitch control feature though.
Ray.
Old 2nd May 2006, 02:03 PM   #6
Hi Ray,
Actually this is my first option, to bypass the PPL & VCO and connect a kwack clock after this.
Thank you so much for your great help. I really appreciate it.
Cheers......
Farley
Old 2nd May 2006, 02:11 PM   #7
6h5c's Avatar
You're welcome, Farl.
I hope it will give an audible result. Positive result that is
Ray.
Old 2nd May 2006, 03:06 PM   #8
Ruach is offline Ruach  Singapore
I had this player sometime back. The CD7300 does need a lot of work to make it sound really good and the clock part is quite tricky. Good luck
Old 2nd May 2006, 04:06 PM   #9
Hi Ruach,
Can you please give us some idea of what you did with this player, so that I can follow that also?
Thanks,
Farley
Marantz CD7300 Service Manual gbyleveldt Digital Source 0 16th July 2008 11:30 AM
Marantz DV7600 - Clock Upgrade dantwomey Digital Source 0 28th November 2006 07:36 PM
Clock upgrade for Marantz 8260 stvnharr Digital Source 0 4th February 2006 12:13 AM
clock upgrade tonitze Digital Source 8 10th June 2003 01:59 PM
Page generated in 0.09334 seconds (77.20% PHP - 22.80% MySQL) with 11 queries
