New Audigy 2 - 24/192Khz - Page 4 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th November 2002, 12:53 PM   #31
Pjotr's Avatar
Hi Johan,
I know. But how much well recorded software is available at 96kHz that justify the format? Before this will settle some years will pass by IMHO. Microphones that can record up to 50 kHz faithfully are still rare at recording sites, although these exists. So I am wondering what justifies 192 kHz over 96 kHz at he moment? Maybe if you are a pro in the recording business. And even then…
Old 27th November 2002, 02:06 PM   #32
Yes you are right in that how could anyone record anything for such a bandwidth. I for my self bought a professional mic for my own use, and I can be happy if it records up to 20 kHz without too much attenuation and with a S/N ratio better than 60 dB (!).
And how on the earth do anyone know how these devices perform above the 20 kHz listening border? The hifi-freaks always states that listening to a device is at least as important as making measurments. But if it is hard to say for a "normal" person how good a recording sounds (vs looking at mesurments) at say, 1 kHz, who is able to say how the sound "sounds" at 50 kHz? Then the hifi gurus can't use their ears anymore, but have to trust mesurments only. Ok, there was a need for a higher sample rate than 44,1 kHz but maybe this belongs to another tread, also
Old 27th November 2002, 03:54 PM   #33
That's why I'm convinced that all listning tests need to use a double blind methodology ... but that rarely happens.
I did a big search on 'double blind' on google once, and it was some interesting reading. I think the hi-fi industry doesn't much want to hear about this as it turns out a lot of very expensive equipment sounds about the same as some typical consumer stuff.
Does that mean expensive hi-fi is a rip off? No! A Jaguar performs about the same as a Ford Taurus, but Jag is not going to loose sales to Ford.
== John ==
Old 27th November 2002, 04:35 PM   #34
JBL is offline JBL  Canada
JBL's Avatar
Send a message via ICQ to JBL
Their is other reason to record at more than the minimum. If one is doing alot of digital manipulation after the recording having a higher sample rate and also resolution(record at 24 but the wave is 32) will help. It limit the error when doing calculation and mixing etc...
Thats what I think anyway and may not be the general opinion.
---Their is still a limit tought recording at more than 96khz is kind of useless--- ...Would really like recording at 32 bit thought.
Jonathan Blanchard (J.Bl.)
---Nothing is impossible---
Old 2nd December 2002, 01:25 PM   #35
Kay is offline Kay  Germany
Hello,
can anybody post a detailed picture from the board of the audigy2 drive bay?
And I need the pinning of the drive bay connector.
Maybe I like to use this soundcard for my PC, but I don't have a place for the drive bay. So I must build my own.
best regards
Kay
best regards
Kay
Old 2nd December 2002, 07:30 PM   #36
Kay:
I couldn't find pinouts in the manual, but it looks like the same connector as the SB Live!.
I did buy one, but I'll have to return it - several times per DVD, it 'stutters' and then voices aren't sync'd with the sound track. Then it starts breaking up.
I have a hunch this is the first generation board that was recalled, OR I have a driver bug. I have downloaded all the recent drivers (Creative's site doesn't have any newer ones), so if it's a driver bug it isn't fixed yet.
Also, one problem I found was that you can't tell the board to do 4.1. All the '.1' formats with less than 5 channels assume your PC speakers actually have the sub cross over, so there is no actual output on the subwoofer jack in the back. This was fairly frustrating, as I don't have a center channel yet, but do have 4 good speakers and a good sub. Guess it's time to get a center channel.
== John ==
Old 2nd December 2002, 09:23 PM   #37
Hi John,
do you have consult the audigy-Forum at soundblaster.com ?
Maybe you find help.
best regards
Kay
best regards
Kay
Old 3rd December 2002, 01:56 AM   #38
I have to admit I didn't .. but I'm sure it's got to be the board or drivers, the same machine works FINE with an SB Live!
Truth be told, it's a good excuse to get M-Audio's new consumer board when it comes out in a week
But I might check with them and see if it's a common problem
== John ==
Old 30th December 2002, 07:39 PM   #39
Well, I'm dredging this up. In this (lengthy) thread on AVSForum , the M-Audio Revolution is quoted as NOT supporting any kind of 'positional' audio via hardware.
I want a very good audio board for my HTPC, but I ALSO want to play the occasional game. Not having hardware accelerated DirectSound (I guess I could live with not having EAX) is really terrible.
It's a shame, the bass management looks to be much better with the Revo.
Any thoughts? I'm close to going back and getting another Audigy
== John ==
Upgrading from Audigy 2ZS? cjv998 Digital Source 4 17th July 2007 02:41 AM
Audigy 2ZS soundcard pinkmouse Everything Else 9 14th November 2006 09:26 AM
Audigy 2 ZS vs DAC PCM2702 MarasK Digital Source 0 1st July 2005 11:04 AM
Bl**dy Audigy... sugestions, please! sobazz Everything Else 12 7th March 2004 11:48 PM
More Audigy 2 Warning fmak Digital Source 5 9th February 2003 01:49 PM
Copyright ©1999-2017 diyAudio
