Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
New Audigy 2 - 24/192Khz
Old 25th November 2002, 08:33 PM   #21
halcyon is offline halcyon
turtle,
but Audigy (1 and 2 both) has Firewire out
Not that you can use it for DVD-A digital output (at least not yet) AFAIK.
I knew you meant this, but I needed to clarify so others would not misunderstand it.
regards,
Halcyon
Old 25th November 2002, 09:19 PM   #22
johan is offline johan
From what I've read, it doesn't relly matter that the audigy 2 disables spdif out when playing dvd audio, as spdif doesn't have the bandwidth to do dvd-a anyway
From what I know, S/PDIF does not limit what you send through it. It is always possible to send raw audio data through it. The cable does not care what information it delivers. Then it is another thing if there are receivers capable of decoding the signal. An expensive DAC is needed
Old 25th November 2002, 09:33 PM   #23
UrSv is offline UrSv  Sweden
UrSv's Avatar
Originally posted by halcyon
turtle,
regards,
Halcyon
OR it could be possible already:
http://www.1394ta.org/Press/2002Pres...er/9.23.ti.htm
/UrSv
Old 26th November 2002, 09:46 AM   #24
Have to correct myself a bit.
The original S/PDIF standard states:
Audio format : linear 16 bit default, up to 24 bit expandable
Allowed sampling frequencies (Fs) of the audio:
44.1kHz from CD
48 kHz from DAT
32 kHz from DSR
Now manufacturers are already using 24 bit 96 kHz without problems, because there are no limitations in the S/PDIF interface for higher sampling frequencies. I don't see why not 192 kHz could be used. It is just a matter of higher bitrates and getting the right chips.
Note that the professional balanced AES/EBU interface can not without problem use 24 bit, because it uses some bits for other information. This is not the problem with the consumer S/PDIF interface.
Old 26th November 2002, 04:19 PM   #25
jgwinner is offline jgwinner  United States
Johan:
Are the higher bitrates part of an amended spec?
The bit format might be able to carry the non-spec information, but does the bandwidth of the connection itself allow that? (I don't know, I'm asking). With the amount of data you're talking about, it's a lot of bandwidth.
== John ==
Old 26th November 2002, 04:43 PM   #26
tiroth is offline tiroth  United States
AFAIK there are no 192kHz SP/DIF recievers.
Old 26th November 2002, 08:58 PM   #27
No, I don't really know. Of course it is out of the original spec to run for instance 96 kHz, but that is exactly what a lot of PC sound card manufacturers are allowing.
Old 26th November 2002, 09:19 PM   #28
UrSv's Avatar
I don't know any of this stuff really but what is the Sanyo receivers we read about (check LC89055W):
http://www.semic.sanyo.co.jp/solution/vrs/vrs_dir_e.htm
Or (CS8416):
http://www.cirrus.com/design/product...ail.cfm?d=1005
Aren't those 192 kHz SPDIF receivers?
/UrSv
Old 26th November 2002, 09:59 PM   #29
Pjotr is offline Pjotr
Pjotr's Avatar
My M-audio superdac works pretty well at 24bit/96khz connected to an Audiophile 2496 pc card with standard 75 ohm 5 mm CATV coax. As far as I now all M-Audio stuff uses native sample rates, no resampling at all. Only standard oversampling.
But why do you want 192kHz? There are no standard software carriers for it except your harddisc.
Old 27th November 2002, 10:29 AM   #30
What do you mean with "standard software carriers"? DVD-Audio is a standard and it supports 192kHz.
New Audigy 2 - 24/192KhzHide this!Advertise here!
Upgrading from Audigy 2ZS? cjv998 Digital Source 4 17th July 2007 02:41 AM
Audigy 2ZS soundcard pinkmouse Everything Else 9 14th November 2006 09:26 AM
Audigy 2 ZS vs DAC PCM2702 MarasK Digital Source 0 1st July 2005 11:04 AM
Bl**dy Audigy... sugestions, please! sobazz Everything Else 12 7th March 2004 11:48 PM
More Audigy 2 Warning fmak Digital Source 5 9th February 2003 01:49 PM
Copyright ©1999-2017 diyAudio
