Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th April 2006, 09:52 PM   #1
Default passive I/V and transformer
Hi All,
I read about a passive i/v stage and it's possible benefits.
Just connect a resistor from dac output to ground and the connect a wire from pin-side resistor lead to rca.
Output is very low. I read somewhere that this signal can be boosted with different types of outputs stages (tube, opamp of course, and transformer)
I have not yet got the tube skills and opamps are already present. But how to implement a transformer after this dac output with pasive i/v and before rca. Is there still need for output caps?
{Marantz CD-7 Guido Tent Clock ---> HMS Sestetto MKII XLR ---> Electrocompaniet ECI-4 ---> Kimber 8TC ---> Eros MKII DIY}
Old 29th April 2006, 07:00 AM   #2
It's dead easy. Just take a look at e.g. the wiring diagram of the Sowter 8347. Experiment with I/V resistor values but don't go too high. No need for output caps but make sure that no DC is applied to either primary or secondary windings of your transformer!
Old 29th April 2006, 04:46 PM   #3
Those transformers are expensive, though. I contacted Sowter about a suitable transformer for the PCM1794, and they recommended 9762, which costs ~$120!
Old 29th April 2006, 10:15 PM   #4
Won't any transformer with suitable gain do?
Old 30th April 2006, 08:29 AM   #5
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Hi.
I bought a pair of audio transformers off EBAY just for this purpose. Nice mu-metal screened cans. There is still 1 available on Ebay listing no. 7605809903
http://cgi.ebay.ie/Audio-Transformer...QQcmdZViewItem
They are 1 + 1 : 2 + 2 ratio.
Low dc resistance and depending on how they are wired 75 to 600ohm impedance.
suitably connected they should give a reasonable voltage step-up.
I think they are available from Farnell or RS.
Part No. is A262A2C ( Oxford Electrical Products)
Andy
Old 30th April 2006, 09:20 AM   #6
Isn't a 1:1 useless, because there is no gain?
Old 30th April 2006, 09:22 AM   #7
poynton's Avatar
Hi.
Yes, 1:1 would be useless - no gain
But parallel the input and series the output gives 1:4
Read the spec :
http://www.farnell.com/datasheets/9126.pdf
Andy
Old 30th April 2006, 09:26 AM   #8
Do not see this in spec-sheet 1:4
Just see 1+1:6,45
(please note I am a novice with this type of circuitry)
Old 30th April 2006, 09:32 AM   #9
poynton's Avatar
Just see 1+1:6,45
The spec sheet is for 3 types of transformer.
Look at the centre spec. for the type I bought. [although this was only given as an example]
If you bought the other type you would get 1 : 12.9 ratio !!
Andy
Old 30th April 2006, 11:00 AM   #10
dddac is offline dddac  Germany
The voltage output by using a "simple" resistor, is not low per definition. It entirely depends on the DAC chip you are using. a 1541 will end up with 25mV or so, a PCM63 does 100mV, a TDA1543 (running at 8volt) can do almost 2 volt etc etc...
If you are low, you will get very good results with the sowters. 120$ expensive? a normal amplifying stage will cost much more. How much did your DAC cost and your speakers ?
Any way, I have had very good results with 3 projects where I used the Sowters (PCM63 DAC and 2 upgrades for Sony SACD playaers)
You can read about this projects, with published circuits at my web site click here to go to my Site
Oh, almost forgot: transformers will only work properly if the input impedance of the next stage is high. A 10k inputs will transform back to 25 Ohm, which will lower the output of the DAC again ! I use 200k Volume pot for hat reason
www.dddac.de
Happy listening and building
passive I/V directly into transformer ? Bernhard Digital Source 6 17th August 2005 08:39 PM
Transformer Based Passive Preamp wytco0 Solid State 5 6th September 2004 06:58 PM
passive preamp with transformer output - which parts to use? krishu Parts 9 1st June 2004 04:33 PM
weird passive transformer problem sef Everything Else 0 3rd November 2003 06:05 PM
DIY DAC suitable for passive transformer linestage (TVC)? Saurav Digital Source 2 19th August 2003 12:40 AM
Page generated in 0.10392 seconds (80.19% PHP - 19.81% MySQL) with 10 queries
