Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th April 2006, 03:29 PM   #1
Default cd6000 fault
Good sirs of diyaudio. I require your assistance.
My Marantz cd6000 ose limited edition is no longer working.
Fault description:
screen does not display, no power light, none of the control buttons on the front work, remote does no work.
When powered on I can hear the transformer power up.
I have had a multimeter on the back of the front panel at the point which the "ribbon" connects. The following voltages were measured.
Top row of pins 0v 0v 5v 5v 0v 0v 0v 0v 21.7v
bottom row of pins 0v 0v 1.2v 5v 5v 5v 5v 21.7v 26.2v
Does anyone have the service manual for this model to check the values?
Has anyone experienced this problem before?
Has anyone got any ideas where to start to find the problem?
Kindest regards
goodlife
Old 28th April 2006, 04:09 PM   #2
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Default Re: cd6000 fault
Fault description:
Kindest regards
goodlife
Hi.
Alongside the transformer are 2 small round devices. Fuses !
They supply the +5v and the 10v supplies.
Check them with your meter - they are a little undersized
Old 28th April 2006, 05:01 PM   #3
thanks for the reply.
not used to fuses like that.
had them both off the board and tested them. Both are fine.
Any other ideas?
Old 28th April 2006, 05:03 PM   #4
andrew_whitham's Avatar
goodlife,
I have the cd6000 service manual. Its 5.5mb drop me a line and I'll mail it
what do you mean you can HEAR the transformer power up? It does sound though, like your not getting any juice to the front board.
I'm sure you've tried this already but make sure everything's properly connected. I lost the left channel on mine, turned out to be due to the glue on the HDAM had gone and it had come loose. About the easiest fix ever...
Andy
Old 28th April 2006, 05:12 PM   #5
when i say i can hear it, i mean there is a slight hum that comes with all transformers when powered up.
Its only audible when you put your ear next to it.
Old 28th April 2006, 05:38 PM   #6
poynton's Avatar
Fault description:
Kindest regards
goodlife
Hi.
The voltages look OK
[ see diagram of connector]
top row is even nos.
bottom row is odd nos.
26.2 = pin 1
andy
Old 28th April 2006, 05:50 PM   #7
poynton's Avatar
hi.
Next, you should check the voltages on the ac supply to the front panel. this is easiest at the ends of resistors 3118, 3119
Also check the voltage at the regulator 7119
The output should be -26v
Andy
Old 28th April 2006, 06:30 PM   #8
whereabouts on the board are they?
I've had a look and cannot find em!!!
Old 28th April 2006, 06:54 PM   #9
poynton's Avatar
opps
I forgot the picture !
Old 28th April 2006, 06:57 PM   #10
poynton's Avatar
psu
marantz cd6000 not playing mor2bz Digital Source 4 11th December 2007 03:58 AM
Modified CD6000 Problem greg_mcquaid Digital Source 7 22nd October 2007 07:46 PM
WTB : Marantz CD6000 - RF board poynton Swap Meet 15 22nd August 2007 01:22 PM
Marantz CD6000 - a little help needed Baka Digital Source 0 3rd May 2006 09:07 AM
Marantz CD6000 - is there I2S signal r!sc! Digital Source 0 2nd August 2003 01:44 AM
Page generated in 0.10823 seconds (82.15% PHP - 17.85% MySQL) with 11 queries
