| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have a CD16, which I've modified with a Trichord DOB.
However, for the past year or so, it has been skipping when reading CDs, and has been getting worse and worse. It's not scratches or dirty discs, but it just skips at random. It affects the DOB outputs, the on-board digital outputs and the analogue outputs. Any clues? The previous owner said that the lasers on them died quickly because they were powered up the whole time that the player was. Is this so, or is it just something gone out of whack? If so, what and how can it be sorted? Thanks in advance! |
#2 |
If indeed it is a version of the CDM4 mech, there probably is a little white plastic pressure plate that the ball bearing for the disc clamp spins against. It eventually gets pitted and this is often the cause of skipping on CDM4. Check this before you check or adjust anything else. Sanding it down with fine grit sandpaper untill smooth often works, otherwise you may need to try and get it as a spare from philips.
#3 |
That's a good bit of info... how do I get to this part of the mech? Does anybody have a manual?
#4 |
DIY !
No need to worry, laser is OFF when in STOP - mode (Power-on).
It is a fairly simple job to replace laser, from a "cheap" CDM-4 unit, there are several stories here if you search! Arne K
Ars longa, vita brevis |
#5 |
diyAudio Moderator Emeritus
When in need for cdm4 please send me a PM.
It's only audio |
| DCD-1550AR strange skipping problem | OneyedK | Digital Source | 0 | 23rd October 2007 09:51 AM |
| Skipping problem with Nad541 cdp | andy2 | Digital Source | 1 | 13th December 2005 06:37 AM |
| Problem of Philips CDM4/19 | ki2518 | Digital Source | 1 | 7th November 2004 03:23 PM |
| CD16 reclock problem | Isaac Sibson | Digital Source | 13 | 11th July 2004 10:12 PM |
| Meridian transport skipping Philips CDM4 | Monkey King | Digital Source | 0 | 23rd May 2004 02:43 AM |
| Page generated in 0.07935 seconds (73.26% PHP - 26.74% MySQL) with 10 queries |
