Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th April 2006, 05:57 PM   #1
Default Need a schematic for Arcam Delta Black Box!
Please can anyone send me one? This is the original DAC (not 5, 50, 500). It has a TDA1541A DAC chip. Thank you. I would really appreciate it.
Old 25th April 2006, 07:10 PM   #2
diyAudio Moderator Emeritus
jean-paul's Avatar
It has TDA1541 without the A ( probably ). Watch your mailbox. I changed the thread title with the correct word for schematic.
It's only audio
Old 25th April 2006, 08:09 PM   #3
ash_dac is offline ash_dac  United Kingdom
Default Re: Need a schematic for Arcam Delta Black Box!
I have it but I think someone has sent it to you.
I haven't used my black box in a while because it sounds too bright to me.
Arcam Delta Black Box1 mods
What are you planning on doing to the black box?
Old 26th April 2006, 02:28 AM   #4
Ruach is offline Ruach  Singapore
Hi Jigga,
You wrote to me earlier asking about Black Box mods. I have not done any mods to the Black Box. You may wish to check with the rest.
Ash_dac - I am surprised that you find the Black Box bright? Did you mod it?
Old 26th April 2006, 02:56 AM   #5
Hey Jean. Thank you very much for the manual. It's weird that mine does have the A on the 1541 chip. Maybe different units?
I'm planning on modding couple things on it. Maybe the caps in the PSU and the digital stage. Change out the lytics on the bypass. Maybe change out the diodes for MUR405's? Change the rca's (they seems little old to me) and change out the Rca input for a BNC input. Any input from you guys would be appreciated also.
Pics are up here:
http://www.villagephotos.com/pubbrow...der_id=1661429
Old 26th April 2006, 03:42 AM   #6
For a start, you can build a separate +5V for the 1541A. It is currently powered by a +6.2V shared power supply.
You can construct a new digital input section using a CS8414 chip
Old 26th April 2006, 04:04 AM   #7
Hey Ruach. I'm just starting into this whole DIY thing. I have no clue how to do either of the two things you recommended. Any links or pics or advice you can provide?
Old 26th April 2006, 12:31 PM   #8
Hi Jigga,
I haven't done much modding to it really. I decoupled saa7220, and tda1541a with oscon capacitors. Then I replaced the wire link with resistor to 'correct' 6.2V. I think it now measures 5.2v from memory . Also replaced tda1541a with tda1541a S1 grade. Corrected the inverted input receiver circuit so it works with my Philips cd723 / Marantz cd63.
I find the black box bright compared to my DPA dac's (bitstream). I'll listen again this week.
Yep I would go for correcting the PSU stage. Is the -15v to the relay the same line as to tda1541a? Might be worth building Jocko's Easy IV stage..
Arcam Delta Black Box1 mods ash_dac Digital Source 51 17th November 2011 07:44 PM
Schematic? for Arcam Delta 290 Bare Solid State 0 2nd June 2005 02:47 AM
Question: clocksynching: Linn Karik w Arcam delta black box 5 charliecochrane Digital Source 0 24th March 2004 10:47 PM
Page generated in 0.09766 seconds (78.80% PHP - 21.20% MySQL) with 10 queries
